I just installed Lubuntu 14.04 on my Dell inspiron 5520. But as often happens with a new operating system, there is no wifi for me now. I can only connect to internet using the ethernet connection. I also looked at Dell's site, they dont have drivers for Ubuntu for this particular laptop.
wireless script output:
########## wireless info START ##########
Report from: 10 Apr 2015 19:44 IST +0530
Booted last: 11 Apr 2015 00:25 IST +0530
Script from: 20 Sep 2014 23:04 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description:    Ubuntu 14.04.2 LTS
Release:    14.04
Codename:   trusty
##### kernel ############################
Linux 3.16.0-30-generic #40~14.04.1-Ubuntu SMP Thu Jan 15 17:43:14 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
Lubuntu
##### lspci #############################
07:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10ec:8136] (rev 05)
    Subsystem: Dell Device [1028:056a]
    Kernel driver in use: r8169
08:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
    Subsystem: Dell Wireless 1704 802.11n + BT 4.0 [1028:0016]
    Kernel driver in use: bcma-pci-bridge
##### lsusb #############################
Bus 002 Device 017: ID 0a5c:21d7 Broadcom Corp. BCM43142 Bluetooth 4.0
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
##### PCMCIA card info ##################
'pccardctl' is not installed (package "pcmciautils").
##### rfkill ############################
5: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
##### lsmod #############################
dell_wmi               12761  0
sparse_keymap          13948  1 dell_wmi
dell_laptop            18168  0
bcma                   52320  0
dcdbas                 14928  1 dell_laptop
wmi                    19193  1 dell_wmi
##### interfaces ########################
auto lo
iface lo inet loopback
##### ifconfig ##########################
eth0      Link encap:Ethernet  HWaddr d4:be:d9:32:70:ff
          inet addr:192.168.1.2  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::d6be:d9ff:fe32:70ff/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:97569 errors:0 dropped:0 overruns:0 frame:0
          TX packets:60735 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:130859069 (130.8 MB)  TX bytes:5258823 (5.2 MB)
##### iwconfig ##########################
eth0      no wireless extensions.
lo        no wireless extensions.
##### route #############################
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.1.1     0.0.0.0         UG    0      0        0 eth0
192.168.1.0     0.0.0.0         255.255.255.0   U     1      0        0 eth0
##### resolv.conf #######################
nameserver 127.0.1.1
##### nm-tool ###########################
NetworkManager Tool
State: connected (global)
- Device: eth0  [Wired connection 1] -------------------------------------------
  Type:              Wired
  Driver:            r8169
  State:             connected
  Default:           yes
  HW Address:        D4:BE:D9:32:70:FF
  Capabilities:
    Carrier Detect:  yes
    Speed:           100 Mb/s
  Wired Properties
    Carrier:         on
  IPv4 Settings:
    Address:         192.168.1.2
    Prefix:          24 (255.255.255.0)
    Gateway:         192.168.1.1
    DNS:             192.168.1.1
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
WimaxEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
no-auto-default=D4:BE:D9:32:70:FF,
[ifupdown]
managed=false
##### NetworkManager profiles ###########
##### iw reg get ########################
'iw' is not installed (package "iw").
##### iwlist channels ###################
eth0      no frequency information.
lo        no frequency information.
##### iwlist scan #######################
guntbert
  • 13,475
raghavj
  • 31
You can reinstall network-manager and do a proper update for a first investigation. You can restart the service network-manager as well!!
/etc/init.d/network-manager restart
