28
I bought the wireless adapter to use with a computer without internet access but I can't figure out how to install it with just a USB with the driver on it. I've read a few articles on how to install the driver but they all require me to have internet access and I don't have internet. I'm completely new to Ubuntu. If you can help that would be great. Thanks! Ps: I have the latest version of Ubuntu as of 7-5-16.
HDGAMER
  • 283
Please download this file on some other computer and transfer it to the desktop of the subject computer: https://github.com/abperiasamy/rtl8812AU_8821AU_linux/archive/master.zip Right-click it and select 'Extract Here.' Now, in a terminal:
cd ~/Desktop/rtl8812AU_8821AU_linux-master
make
sudo make install
sudo modprobe rtl8812au
Now that we have the wireless working correctly, we'll refine this a bit.
sudo apt-get update
sudo apt-get install dkms
sudo cp -R . /usr/src/rtl8812AU_8821AU_linux-1.0
sudo dkms add -m rtl8812AU_8821AU_linux -v 1.0
sudo dkms build -m rtl8812AU_8821AU_linux -v 1.0
sudo dkms install -m rtl8812AU_8821AU_linux -v 1.0
Eliah Kagan
  • 119,640
chili555
  • 61,330
13
This driver can be installed from the official Ubuntu repositories by
sudo apt install rtl8812au-dkms
Pilot6
  • 92,041
Works on Ubuntu 18.04.4 LTS with kernel head v5.3.xxx using this repo. which you will need to git clone into a local folder
https://github.com/EntropicEffect/rtl8822bu
git clone https://github.com/EntropicEffect/rtl8822bu
Make sure you have build-essentials and dkms
sudo apt-get install build-essential dkms
After cloning, cd into that folder and run
cd rtl8822bu
make
sudo make install
sudo modprobe 88x2bu
Then connect to your Wi-Fi (Hopefully, both 2.4GHz and 5GHz should be detectable now)
Next, follow these steps to refine the installation and for an automatic rebuild on Ubuntu kernel image updates
sudo dkms add .
sudo dkms install -m 88x2bu -v 1.1
Mayank Bhaskar
  • 160
