I was trying to improve the wifi signal range, but when I executed the command sudo modprobe -rv rtl8723bemy wifi stopped working and I cannot do anything.
How I do reset the config or rollback this changes?
Zanna
  • 72,312
The command sudo modprobe -rv rtl8723be removed the module from the running kernel (that's what the -r option does - it's short for --remove).
This doesn't alter any configuration, so the driver will be inserted again on the next boot. To insert it manually, run sudo modprobe rtl8723be (without the -r option). You don't need the -v option; it only makes the command's output more verbose. Also see man modprobe for more information.
Zanna
  • 72,312
danzel
  • 6,533
