The problem is that the device works, even emits light signals indicating operation, but the system does not see available networks (the wifi tab has appeared). The wifi modem does not work and in general it is impossible to connect. Typically, earlier I was able to run everything without problems on Ubuntu 22.04, but having installed another system on the same computer with the same device, I came to this state, and now it doesn’t even work on Ubuntu 22.04. I used this methods:
sudo apt install git dkms
git clone https://github.com/aircrack-ng/rtl8812au.git
cd rtl8812au
sudo make dkms_install
and
git clone https://github.com/jeremyb31/rtl8812au-1.git
cd rtl8812au-1
sudo ./dkms-install.sh
I tried the installation on all of the above systems. Doesn't work on everyone except 22.04 (it worked once on it)
Wireless Info Script:
########## wireless info START ##########
Report from: 22 May 2024 13:44 MSK +0300
Booted last: 22 May 2024 00:00 MSK +0300
Script from: 25 Jan 2020 03:34 UTC +0000
release
Distributor ID: Ubuntu Description: Ubuntu 24.04 LTS Release: 24.04 Codename: noble
kernel
Linux 6.8.0-31-generic #31-Ubuntu SMP PREEMPT_DYNAMIC Sat Apr 20 00:40:06 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
desktop
Ubuntu
lspci
00:19.0 Ethernet controller [0200]: Intel Corporation 82579LM Gigabit Network Connection (Lewisville) [8086:1502] (rev 04) Subsystem: Hewlett-Packard Company 82579LM Gigabit Network Connection (Lewisville) [103c:161c] Kernel driver in use: e1000e
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 001 Device 003: ID 138a:003c Validity Sensors, Inc. VFS471 Fingerprint Reader Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 002 Device 004: ID 04f2:b230 Chicony Electronics Co., Ltd Integrated HP HD Webcam Bus 002 Device 005: ID 03f0:231d HP, Inc Broadcom 2070 Bluetooth Combo Bus 002 Device 009: ID 0781:5567 SanDisk Corp. Cruzer Blade Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 005: ID 058f:6387 Alcor Micro Corp. Flash Drive Bus 003 Device 007: ID 04e8:6863 Samsung Electronics Co., Ltd Galaxy series, misc. (tethering mode) Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
PCMCIA card info
rfkill
0: hci0: Bluetooth Soft blocked: no Hard blocked: no
secure boot
This system doesn't support Secure Boot
lsmod
hp_wmi 28672 0 sparse_keymap 12288 1 hp_wmi platform_profile 12288 1 hp_wmi wmi_bmof 12288 0 wmi 32768 3 hp_wmi,video,wmi_bmof
interfaces
ifconfig
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback <MAC address> brd <MAC address> inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: enp0s25: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000 link/ether <MAC 'enp0s25' [IF1]> brd <MAC address> 3: enx<IF from MAC [IF2]>: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000 link/ether <MAC 'enx<IF from MAC [IF2]>' [IF2]> brd <MAC address> inet 192.168.190.198/24 brd 192.168.190.255 scope global dynamic noprefixroute enx<IF from MAC [IF2]> valid_lft 3590sec preferred_lft 3590sec inet6 fe80::3a80:632:ab1e:9451/64 scope link noprefixroute valid_lft forever preferred_lft forever
iwconfig
lo no wireless extensions.
enp0s25 no wireless extensions.
enx<IF from MAC [IF2]> no wireless extensions.
route
default via 192.168.190.18 dev enx<IF from MAC [IF2]> proto dhcp src 192.168.190.198 metric 100 192.168.190.0/24 dev enx<IF from MAC [IF2]> proto kernel scope link src 192.168.190.198 metric 100
resolv.conf
[777 root '/etc/resolv.conf' -> '../run/systemd/resolve/stub-resolv.conf']
nameserver 127.0.0.53 options edns0 trust-ad search .
network managers
Installed:
NetworkManager
Running:
root 1040 1 0 13:29 ? 00:00:00 /usr/sbin/NetworkManager --no-daemon
NetworkManager info
GENERAL.DEVICE: enx<IF from MAC [IF2]> GENERAL.TYPE: ethernet GENERAL.NM-TYPE: NMDeviceEthernet GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/3 GENERAL.VENDOR: Samsung Electronics Co., Ltd GENERAL.PRODUCT: Galaxy series, misc. (tethering mode) GENERAL.DRIVER: rndis_host GENERAL.DRIVER-VERSION: 6.8.0-31-generic GENERAL.FIRMWARE-VERSION: RNDIS device GENERAL.HWADDR: <MAC 'enx<IF from MAC [IF2]>' [IF2]> GENERAL.MTU: 1500 GENERAL.STATE: 100 (connected) GENERAL.REASON: 0 (No reason given) GENERAL.IP4-CONNECTIVITY: 4 (full) GENERAL.IP6-CONNECTIVITY: 3 (limited) GENERAL.UDI: /sys/devices/pci0000:00/0000:00:1c.7/0000:25:00.0/usb3/3-1/3-1:1.0/net/enx<IF from MAC [IF2]> GENERAL.PATH: pci-0000:25:00.0-usb-0:1:1.0 GENERAL.IP-IFACE: enx<IF from MAC [IF2]> GENERAL.IS-SOFTWARE: no GENERAL.NM-MANAGED: yes GENERAL.AUTOCONNECT: yes GENERAL.FIRMWARE-MISSING: no GENERAL.NM-PLUGIN-MISSING: no GENERAL.PHYS-PORT-ID: -- GENERAL.CONNECTION: Wired connection 1 GENERAL.CON-UUID: ead36809-5af9-343b-9acf-f6793a8212e2 GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/2 GENERAL.METERED: yes (guessed) CAPABILITIES.CARRIER-DETECT: yes CAPABILITIES.SPEED: unknown CAPABILITIES.IS-SOFTWARE: no CAPABILITIES.SRIOV: no INTERFACE-FLAGS.UP: yes INTERFACE-FLAGS.LOWER-UP: yes INTERFACE-FLAGS.CARRIER: yes INTERFACE-FLAGS.PROMISC: no WIRED-PROPERTIES.CARRIER: on IP4.ADDRESS[1]: 192.168.190.198/24 IP4.GATEWAY: 192.168.190.18 IP4.ROUTE[1]: dst = 192.168.190.0/24, nh = 0.0.0.0, mt = 100 IP4.ROUTE[2]: dst = 0.0.0.0/0, nh = 192.168.190.18, mt = 100 IP4.DNS[1]: 192.168.190.18 DHCP4.OPTION[1]: broadcast_address = 192.168.190.255 DHCP4.OPTION[2]: dhcp_client_identifier = 01:<MAC 'enx<IF from MAC [IF2]>' [IF2]> DHCP4.OPTION[3]: dhcp_lease_time = 3599 DHCP4.OPTION[4]: dhcp_server_identifier = 192.168.190.18 DHCP4.OPTION[5]: domain_name_servers = 192.168.190.18 DHCP4.OPTION[6]: expiry = 1716378237 DHCP4.OPTION[7]: host_name = axolotsh-HP DHCP4.OPTION[8]: ip_address = 192.168.190.198 DHCP4.OPTION[9]: next_server = 192.168.190.18 DHCP4.OPTION[10]: requested_broadcast_address = 1 DHCP4.OPTION[11]: requested_domain_name = 1 DHCP4.OPTION[12]: requested_domain_name_servers = 1 DHCP4.OPTION[13]: requested_domain_search = 1 DHCP4.OPTION[14]: requested_host_name = 1 DHCP4.OPTION[15]: requested_interface_mtu = 1 DHCP4.OPTION[16]: requested_ms_classless_static_routes = 1 DHCP4.OPTION[17]: requested_nis_domain = 1 DHCP4.OPTION[18]: requested_nis_servers = 1 DHCP4.OPTION[19]: requested_ntp_servers = 1 DHCP4.OPTION[20]: requested_rfc3442_classless_static_routes = 1 DHCP4.OPTION[21]: requested_root_path = 1 DHCP4.OPTION[22]: requested_routers = 1 DHCP4.OPTION[23]: requested_static_routes = 1 DHCP4.OPTION[24]: requested_subnet_mask = 1 DHCP4.OPTION[25]: requested_time_offset = 1 DHCP4.OPTION[26]: requested_wpad = 1 DHCP4.OPTION[27]: routers = 192.168.190.18 DHCP4.OPTION[28]: subnet_mask = 255.255.255.0 IP6.ADDRESS[1]: fe80::3a80:632:ab1e:9451/64 IP6.GATEWAY: -- IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 1024 CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/3 CONNECTIONS.AVAILABLE-CONNECTIONS[1]: ead36809-5af9-343b-9acf-f6793a8212e2 | Wired connection 1
GENERAL.DEVICE: enp0s25 GENERAL.TYPE: ethernet GENERAL.NM-TYPE: NMDeviceEthernet GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/2 GENERAL.VENDOR: Intel Corporation GENERAL.PRODUCT: 82579LM Gigabit Network Connection (Lewisville) GENERAL.DRIVER: e1000e GENERAL.DRIVER-VERSION: 6.8.0-31-generic GENERAL.FIRMWARE-VERSION: 0.13-4 GENERAL.HWADDR: <MAC 'enp0s25' [IF1]> GENERAL.MTU: 1500 GENERAL.STATE: 20 (unavailable) GENERAL.REASON: 2 (Device is now managed) GENERAL.IP4-CONNECTIVITY: 1 (none) GENERAL.IP6-CONNECTIVITY: 1 (none) GENERAL.UDI: /sys/devices/pci0000:00/0000:00:19.0/net/enp0s25 GENERAL.PATH: pci-0000:00:19.0 GENERAL.IP-IFACE: -- GENERAL.IS-SOFTWARE: no GENERAL.NM-MANAGED: yes GENERAL.AUTOCONNECT: yes GENERAL.FIRMWARE-MISSING: no GENERAL.NM-PLUGIN-MISSING: no GENERAL.PHYS-PORT-ID: -- GENERAL.CONNECTION: -- GENERAL.CON-UUID: -- GENERAL.CON-PATH: -- GENERAL.METERED: unknown CAPABILITIES.CARRIER-DETECT: yes CAPABILITIES.SPEED: unknown CAPABILITIES.IS-SOFTWARE: no CAPABILITIES.SRIOV: no INTERFACE-FLAGS.UP: yes INTERFACE-FLAGS.LOWER-UP: no INTERFACE-FLAGS.CARRIER: no INTERFACE-FLAGS.PROMISC: no WIRED-PROPERTIES.CARRIER: off IP4.GATEWAY: -- IP6.GATEWAY: -- CONNECTIONS.AVAILABLE-CONNECTION-PATHS: --
NetworkManager.state
[main] NetworkingEnabled=true WirelessEnabled=true WWANEnabled=true
NetworkManager config
[[/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf]] [connection] wifi.powersave = 3
[[/etc/NetworkManager/NetworkManager.conf]] [main] plugins=ifupdown,keyfile [ifupdown] managed=false [device] wifi.scan-rand-mac-address=no
[[/usr/lib/NetworkManager/conf.d/10-dns-resolved.conf]] [main] dns=systemd-resolved
[[/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf]] [keyfile] unmanaged-devices=*,except:type:wifi,except:type:gsm,except:type:cdma
[[/usr/lib/NetworkManager/conf.d/20-connectivity-ubuntu.conf]] [connectivity] uri=http://connectivity-check.ubuntu.com./
[[/usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf]] [device-31-mac-addr-change] match-device=driver:eagle_sdio,driver:wl wifi.scan-rand-mac-address=no
NetworkManager profiles
Netplan config
[/etc/netplan/01-network-manager-all.yaml] network: version: 2 renderer: NetworkManager
grep: /etc/netplan/50-cloud-init.yaml: Permission denied grep: /lib/netplan/00-network-manager-all.yaml: Permission denied
iw reg get
'iw' is not installed (package "iw").
iwlist channels
lo no frequency information.
enp0s25 no frequency information.
enx<IF from MAC [IF2]> no frequency information.
iwlist scan
lo Interface doesn't support scanning.
enp0s25 Interface doesn't support scanning.
enx<IF from MAC [IF2]> Interface doesn't support scanning.
module infos
module parameters
/etc/modules
modprobe options
[/etc/modprobe.d/amd64-microcode-blacklist.conf] blacklist microcode
[/etc/modprobe.d/blacklist-ath_pci.conf] blacklist ath_pci
[/etc/modprobe.d/blacklist.conf] blacklist evbug blacklist usbmouse blacklist usbkbd blacklist eepro100 blacklist de4x5 blacklist eth1394 blacklist snd_intel8x0m blacklist snd_aw2 blacklist prism54 blacklist bcm43xx blacklist garmin_gps blacklist asus_acpi blacklist snd_pcsp blacklist pcspkr blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf] alias net-pf-3 off alias net-pf-6 off alias net-pf-9 off alias net-pf-11 off alias net-pf-12 off alias net-pf-19 off alias net-pf-21 off alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf] blacklist microcode
[/etc/modprobe.d/iwlwifi.conf] remove iwlwifi
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod)
&& /sbin/modprobe -r mac80211
rc.local
grep: /etc/rc.local: No such file or directory
pm-utils
udev rules
dmesg
[ 936.842673] rndis_host 3-1:1.0 enx<IF from MAC [IF2]>: renamed from usb0
########## wireless info END ############
