I am helping a friend troubleshoot her new Lenovo Yoga 2, running a fresh install of Ubuntu 14.04. She's getting kicked off of wireless networks a lot, and her connection is super slow. I'm running 14.04 on a Lenovo X1 and using the same wireless network and not having any trouble.
When I run nm-tool I see (among other things):
Capabilities:
   Speed:           54 Mb/s
She sees:
Capabilities:
   Speed:           9 Mb/s
Similarly, iwconfig shows a much slower connection for her:
hilary@hilary:~$ iwconfig
lo        no wireless extensions.
wlan0     IEEE 802.11bgn  ESSID:"Young Turnip"
          Mode:Managed  Frequency:2.437 GHz  Access Point: 00:22:6B:87:D6:6B
          Bit Rate=11 Mb/s   Tx-Power=16 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
          Link Quality=34/70  Signal level=-76 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:1  Invalid misc:126   Missed beacon:0
I see Bit Rate=54 Mb/s when I run iwconfig.
I spotted this question: https://askubuntu.com/questions/387922/slow-wireless-connection-on-lenovo But I'm not clear on what he's actually disabling there.
Per My wireless/WiFi connection does not work. What information is needed to diagnose the issue?, here are the full diagnostics: script results
How do we troubleshoot this?
Amanda
  • 9,723
  1. Maybe it make a difference if you disable the power save options with:
    sudo iw dev wlan0 set power_save off
  2. Also you can try if it makes a difference if you disable the 11n extension with the following:
    sudo su
    echo "options iwlwifi 11n_disable=1" >> /etc/modprobe.d/iwlwifi.conf
    You need to reboot after this.
You can monitor the speed with
 watch -d -c "sudo nm-tool |grep -i speed "
rubo77
  • 34,024
  • 52
  • 172
  • 299
