Experience level with LUI: total noob Netbook: Acer One, intel Atom with Win XP, 32-bit
Hi all, I've searched and searched but finally I'm stuck at this point. Maybe the answer is in another forum but it seems there are always very specific things that are sliiiightly different that mine. There are a couple weird things during installation that aren't usually mentioned in most of the tutorials.. I'll mention it in case it's relevant. It's quite possible this is just the noob in me speaking.. anyways:
After installing Lubuntu desktop and rebooting the first time, I was prompted to select either win xp or lubuntu during startup, so of course I selected lubuntu. But it went back to windows desktop. I tried rebooting a couple times, then on one I hit F12 to give me the option again and after selecting lubuntu a second time, it loaded/installed.
But, during that initial install, the message "Serious errors were found while checking the disk drive for /." displayed. So, finally I tracked down this discussion Ubuntu 14.04 not booting after error message. /tmp could not be mounted after which I changed "ro" to "rw" (despite the top saying something slightly different that GUN Grub2.. I can't remember exactly but I suspect it's related to mine being Lubuntu, and that topic being Ubuntu). Anyway, it worked and loaded to the Ubuntu desktop (!!!).
I've never had it hardwired into a network, only ever using it with wifi from what I can remember - I want to maintain the netbook's ability to auto detect any wifi networks, as I plan to use this when I'm in hostels, traveling, etc. Just something simple. So far, when I go to menu>preferences>network connections, the only option is Ethernet...
The closest fix I've found is here https://answers.launchpad.net/ubuntu/+source/gnome-nettool/+question/218406 So, I entered
sudo lshw -C network -numeric ; lsb_release -rcd ; uname -r ; lspci -nnk | grep -iA2 net ; lsusb ; rfkill list all ; dmesg | egrep 'error|irmware|NET|wlan'
Which gives me:
*-network
       description: Ethernet interface
       product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10EC:8136]
       vendor: Realtek Semiconductor Co., Ltd. [10EC]
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: eth0
       version: 02
       serial: 00:23:8b:99:5c:b3
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:44 ioport:3000(size=256) memory:71010000-71010fff memory:71000000-7100ffff memory:71020000-7103ffff
  *-network
       description: Wireless interface
       product: AR242x / AR542x Wireless Network Adapter (PCI-Express) [168C:1C]
       vendor: Qualcomm Atheros [168C]
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlan0
       version: 01
       serial: 00:24:2c:09:e8:f3
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=ath5k driverversion=3.13.0-24-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11bg
       resources: irq:18 memory:75200000-7520ffff
Description:    Ubuntu 14.04 LTS
Release:    14.04
Codename:   trusty
3.13.0-24-generic
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10ec:8136] (rev 02)
    Subsystem: Acer Incorporated [ALI] Device [1025:015b]
    Kernel driver in use: r8169
03:00.0 Ethernet controller [0200]: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter (PCI-Express) [168c:001c] (rev 01)
    Subsystem: Foxconn International, Inc. Device [105b:e008]
    Kernel driver in use: ath5k
Bus 001 Device 002: ID 0c45:62c0 Microdia Sonix USB 2.0 Camera
Bus 001 Device 003: ID 0781:5530 SanDisk Corp. Cruzer
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
[    0.105388] NET: Registered protocol family 16
[    0.118924] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[    0.201248] ACPI: Marking method _OSC as Serialized because of AE_ALREADY_EXISTS error
[    0.296167] NET: Registered protocol family 2
[    0.296858] NET: Registered protocol family 1
[    1.321609] NET: Registered protocol family 10
[    1.322222] NET: Registered protocol family 17
[   18.667596] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   22.330173] NET: Registered protocol family 31
[   29.905484] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   29.907200] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   29.928574] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   29.930249] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
...Annnnnd now I'm stuck here.
Maybe I should've chosen a desktop that wasn't "so" light because now I have to figure out everything (clock, wifi, icons, etc etc).
Any suggestions would be appreciated. Also, if there is anything in the above copied/pasted text that I should avoid showing in public, can someone please advise out of the kindness of their heart?
Thanks!
Do:
echo "options ath5k nohwcrypt=1" | sudo tee /etc/modprobe.d/ath5k.conf
sudo modprobe -rfv ath5k
sudo modprobe -v ath5k
Do:
sudo dpkg-reconfigure resolvconf
and then answer 'Yes' to the "Prepare /etc/resolv.conf for dynamic updates" question and No to the one about temporarily appending your existing config to the dynamic one, then reboot, does it connect? if not post a new file from the script.
Wild Man
  • 8,327
