My wifi was working perfectly, but after a failed attempt to install an Nvme SSD (which involved numerous Ubuntu 20 and then 19 installations from USB to that new SSD) I had to fall back and reinstall Ubuntu 19.10 on my original drive.
After doing so there is no Wifi support in the network applet or in the system menu (top right on my desktop), but there is wired connection support in both. The wifi menu is also now not visible when booting from USB. My wired connection works properly.
Based on this question (My wireless/WiFi connection does not work. What information is needed to diagnose the issue?) I've generated a network diagnostic dump and copied to pastebin at https://pastebin.com/44cwwb5V
output of lspci -knn | grep Net -A3; rfkill list is as follows
00:14.3 Network controller [0280]: Intel Corporation Cannon Point-LP CNVi [Wireless-AC] [8086:9df0] (rev 30)
    DeviceName: Onboard - Ethernet
    Subsystem: Intel Corporation Cannon Point-LP CNVi [Wireless-AC] [8086:0000]
    Kernel driver in use: iwlwifi
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
Output of dmesg | grep iwl is as follows:
dmesg | grep iwl
[    4.584148] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    4.602662] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
[    4.602664] iwlwifi 0000:00:14.3: Found debug configuration: 0
[    4.603065] iwlwifi 0000:00:14.3: loaded firmware version 46.6bf1df06.0 op_mode iwlmvm
[    4.721463] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9460, REV=0x318
[    4.732443] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[    4.732911] iwlwifi 0000:00:14.3: Allocated 0x00400000 bytes for firmware monitor.
[    4.737671] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[    4.737678] iwlwifi 0000:00:14.3: Not valid error log pointer 0x00000000 for Init uCode
[    4.737708] iwlwifi 0000:00:14.3: Fseq Registers:
[    4.737718] iwlwifi 0000:00:14.3: 0xCAAAFDB7 | FSEQ_ERROR_CODE
[    4.737727] iwlwifi 0000:00:14.3: 0x39FF0DCF | FSEQ_TOP_INIT_VERSION
[    4.737737] iwlwifi 0000:00:14.3: 0x82B7EC7C | FSEQ_CNVIO_INIT_VERSION
[    4.737740] iwlwifi 0000:00:14.3: 0xDFE4D94D | FSEQ_OTP_VERSION
[    4.737751] iwlwifi 0000:00:14.3: 0x45B05A33 | FSEQ_TOP_CONTENT_VERSION
[    4.737760] iwlwifi 0000:00:14.3: 0xB78CCEC4 | FSEQ_ALIVE_TOKEN
[    4.737770] iwlwifi 0000:00:14.3: 0x899F4F6A | FSEQ_CNVI_ID
[    4.737780] iwlwifi 0000:00:14.3: 0x2F3462E4 | FSEQ_CNVR_ID
[    4.737791] iwlwifi 0000:00:14.3: 0x01000100 | CNVI_AUX_MISC_CHIP
[    4.737834] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
[    4.737909] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[    4.737984] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[    4.738215] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0xa5a5a5a2, CPU2 Status: 0xa5a5a5a2
[    4.738218] iwlwifi 0000:00:14.3: Failed to start INIT ucode: -5
[    4.738222] iwlwifi 0000:00:14.3: Collecting data: trigger 16 fired.
[    4.984307] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
[    4.995478] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -5
Help appreciated
Pilot6
  • 92,041
Greg
  • 41
You have wrong entries in /etc/modprobe.d/iwlwifi.conf.
Replace the contents of this file with
# /etc/modprobe.d/iwlwifi.conf
# iwlwifi will dyamically load either iwldvm or iwlmvm depending on the
# microcode file installed on the system.  When removing iwlwifi, first
# remove the iwl?vm module and then iwlwifi.
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
Pilot6
  • 92,041
