I'm new to Ubuntu OS. I've installed ubuntu 14.04 x64 on my ASUS X550LC laptop yesterday. The wifi signal is weak & getting disconnected sometimes.
Searched all over the web but many site/forums has discussed with Atheros network adapter but the one I have is Ralink RT3290.
This what my iwconfig gives:
ppp0      no wireless extensions.
eth0      no wireless extensions.
lo        no wireless extensions.
usbpn0    no wireless extensions.
wlan0     IEEE 802.11bgn  ESSID:off/any
      Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
      Retry  long limit:7   RTS thr:off   Fragment thr:off
      Power Management:off
Surya
  • 33
We need to install the 3290 driver go here and download the driver then:
We need to install some prerequisites to be able to compile the new driver.
sudo apt-get install --reinstall linux-headers-generic linux-headers-$(uname -r) build-essential dkms
We need to change to the directory the driver was downloaded too which should be the downloads folder.
Please copy and paste all commands one line at a time for accuracy:
cd Downloads
Now untar the driver to /usr/src directory
 sudo tar -xf rt3290sta-2.6.0.0.dkms.tar -C /usr/src
then do:
sudo dkms install -m rt3290sta -v 2.6.0.0 --force
echo "blacklist rt2800pci" | sudo tee -a /etc/modprobe.d/blacklist.conf
echo "blacklist rt2x00pci" | sudo tee -a /etc/modprobe.d/blacklist.conf
Reboot. The directions to install come from the readme file of the driver and my own.
Now, check the settings in the router. WPA2-AES is preferred; not WPA and WPA2 mixed mode and certainly not TKIP. Second, if your router is capable of N speeds, I have better luck with a channel width of 20 MHz in the 2.4 GHz band instead of automatic 20/40 MHz.
I also have better luck with a fixed channel, either 1, or 11, rather than automatic channel selection. After making these changes, reboot the router.
Next, I recommend that your regulatory domain be set explicitly. Check yours:
sudo iw reg get
If you get 00, that is a one-size-fits-all setting. Find yours here: Country Code Then set it temporarily:
sudo iw reg set IS
Of course, substitute your country code if not Iceland. Set it permanently:
gksudo gedit /etc/default/crda
Use nano or kate or leafpad if you don't have the text editor gedit.
Change the last line to read:
REGDOMAIN=IS
Proofread carefully, save and close the text editor.
Next, I'd set IPv6 to Ignore in Network Manager: IPV6 setting This example is for ethernet, but you want wireless.
Wild Man
  • 8,327
