When I installed Ubuntu for the first time I had to do some work with the terminal because my Wi-Fi reception was lower than on Windows:
echo "options rtl8723be ips=0 fwlps=0 ant_sel=1" | sudo tee /etc/modprobe.d/rtl8723be.conf
After updating Ubuntu to bionic beaver my Wi-Fi randomly stops and my browser says that I am not connected to internet. I need to turn off and on my Wi-Fi to use the network. I searched on internet and I followed instructions in this answer. Now my pc says "no Wi-Fi adapter found"
I tried doing:
sudo apt-get install --reinstall bcmwl-kernel-source
with a reboot. And I have also tried:
sudo apt remove bcmwl-kernel-source && sudo apt install git dkms
git clone -b extended https://github.com/lwfinger/rtlwifi_new.git
sudo dkms add ./rtlwifi_new
sudo dkms install rtlwifi-new/0.6
but nothing.
lshw -C network says that my wireless net adapter is unclaimed:
  *-network UNCLAIMED
   description: Network controller
   product: RTL8723BE PCIe Wireless Network Adapter
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:02:00.0
   version: 00
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress cap_list
   configuration: latency=0
   resources: ioport:2000(size=256) memory:91200000-91203fff
What can I do? I am fairly new with Ubuntu.
Edit:
I have tried this answer, but it says "Unable to locate package rtlwifi-new-dkms"
pomsky
  • 70,557
Ken
  • 43
What kernel version are you running?
You can type uname -r in a terminal to get it
I spent long hours to figure out that the problem had something to do with the 4.15.0-33-generic kernel. I switched to the previous one (-32) and everything worked again.
However, i just managed to install the "rtlwifi_new" you mentioned, and now wifi seems to be fine even on latest one.
So, on the 33 kernel, I plugged in the eth cable and executed the following commands:
  • sudo apt-get install build-essential git
  • git clone https://github.com/lwfinger/rtlwifi_new/
  • cd rtlwifi_new
  • make
  • sudo make install
And in rc.local script I've put these two commands:
  • sudo modprobe -r rtl8723be
  • sudo modprobe rtl8723be ant_sel=1
Then I rebooted the system
Hope this can help
Loris
  • 56
That unload/reload of rtl8723be may not work. Under some circumstances, the chip remembers the ant_sel option and ignores the one set on antenna reload. The safer way is to create an options file in /etc/modprobe.d/ that sets the ant_sel option.
Also be aware that there have been changes in the btcoex code that changed the best value from 1 to 2.
