I have a problem,
I have no Ethernet cable and I want to bypass the need of using it to install the WLAN and Wi-Fi Ubuntu driver. I did find a similar question here, but it is old and the answer is not exactly what I wanted. I want to install the driver from the Internet from OS X, and put it onto the USB. Then I will boot to Ubuntu partition, and install the driver from the USB. Is there a way to do it?
A possibility would also be to download it from Ubuntu on VirtualBox, which I officially intended to delete and move it to a partition, and then put it onto a USB
~$ lspci -nn | grep 0280
02:00.0 Network controller [0280]: Broadcom Corporation BCM4331 802.11a/b/g/n [14e4:4331]
Probably the standard MAC controller? I have an MBP 13-inch mid 2012
UPDATE: Decided to download from a .deb package. On the site it says (located here), that the firmware installer supports 4331. When i try to install it, it says: BCM4331 not supported. and in the software center, it says:
Supported Chipsets:
BCM4306/3
BCM4311
BCM4318
BCM4321
BCM4322 (only 14e4:432b)
UPDATE: I also tried a Broadcom patch to support, though it has no effect. The b43 driver in /lib/firmware didn't load, though i'm going to ask a separate question on that.
UPDATE: I found out why the B43 didn't load. Right at boot, before the login screen, this shows up in white text:
[   14.674744] irq 17: nobody cared (try booting withe the "irqpoll" option)
[   14.674801] handlers:
[   14.674809] [<ffffffffa00188b0>] sdhci_irq [sdhci]
[   14.674810] Disabling IRQ #17
[   14.717124] b43-phy0 ERROR: Firmware file "b43/ucode29_mimo.fw" not found
[   14.717125] b43-phy0 ERROR: Firmware file "b43-open/ucode29_mimo.fw not found
[   14.717126] b43-phy0 ERROR: Youmust go to http://wireless.kernel.org/en/users/Drivers/b43devicefirmware and download the correct
version. Please carefully read all instructions on this website
What does this mean and how do I fix this?
John K
  • 455
From other computer which has internet connection, or by using wired connection, do the following steps (copy to mbp and do make-make install):
wget http://bues.ch/b43/fwcutter/b43-fwcutter-018.tar.bz2 http://bues.ch/b43/fwcutter/b43-fwcutter-018.tar.bz2.asc
tar xjf b43-fwcutter-018.tar.bz2
cd b43-fwcutter-018
make
sudo make install
cd ..
For Linux kernel 3.2 and newer we need to download and install version 5.100.138 of Broadcom’s proprietary driver (also from other computer which has internet connection and install it in mbp):
wget http://www.lwfinger.com/b43-firmware/broadcom-wl-5.100.138.tar.bz2
tar xjf broadcom-wl-5.100.138.tar.bz2
mkdir -p lib/firmware
sudo b43-fwcutter -w "lib/firmware" broadcom-wl-5.100.138/linux/wl_apsta.o
The next step is to activate/deactivate one of wireless drivers because we have more than one. To deactivate,
sudo modprobe -r b43 bcma
sudo modprobe -r wl
And to activate,
sudo modprobe b43
sudo modprobe wl
streof
sugab
  • 4,417
