I'm new to the Linux world and I've already got a problem. The Wi-Fi connection on my mini PC (Beelink BT3-Pro) doesn't work. LAN connection works fine, but right now I can't use the Wi-Fi connection. I can "turn" it on but nothing happens. Before Lubuntu I've tried Elementary OS and I had the same problem. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller That's the name of the connection board. I've read online that it has a problem with Linux. I've also tried to follow few guides but I always get errors over errors. On Windows 10 the Wi-Fi connection used to work flawless. What can I do? I'm on the latest Lubuntu version. Also, could you explain to me every single step? I doesn't know Linux at all, but I want to learn!
EDIT: added result for:lspci -nnk | grep -iA3 net; uname -r
01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 0c)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:0123]
Kernel driver in use: r8169
Kernel modules: r8169
6.2.0-39-generic
Results for lsusb:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 002: ID 046d:c31c Logitech, Inc. Keyboard K120
I've used the uname -r command:
6.2.0-39-generic
Results for neofetch:
OS: Lubuntu 22.04.3 LTS x86_64
Host: BT3 Pro BT3 Pro V01
Kernel: 6.2.0-39-generic
Uptime: 35 mins
Packages: 1911 (dpkg), 16 (snap)
Shell: bash 5.1.16
Resolution: 1920x1080
DE: LXQt 0.17.1
WM: Openbox
Theme: Arc-Darker [GTK2/3]
Icons: ePapirus [GTK2/3]
Terminal: qterminal
Terminal Font: Ubuntu Mono 14
CPU: Intel Atom x5-Z8350 (4) @ 1.920GHz
GPU: Intel Atom/Celeron/Pentium Processor x5-E8
Memory: 2290MiB / 3831MiB
Thank you Guiverc, this command is so cool!
I've watched a video of a teardown and there isn't a wifi card to remove :(
Results for the command wget -N -t 5 -T 10 https://github.com/UbuntuForums/wireless-info/raw/master/wireless-info && chmod +x wireless-info && ./wireless-info
Nothing happens if I type modprobe r8169 on the terminal
Results for sudo dmesg| grep -i firm; lsmod | grep cfg
[ 0.162386] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.412293] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 13.388700] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.Beelink-BT3 Pro.bin failed with error -2
[ 13.402744] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.txt failed with error -2
[ 13.421032] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[ 14.125299] sof-audio-acpi-intel-byt 808622A8:00: Firmware info: version 2:0:0-b678a
[ 14.125319] sof-audio-acpi-intel-byt 808622A8:00: Firmware: ABI 3:20:0 Kernel ABI 3:23:0
[ 14.184441] sof-audio-acpi-intel-byt 808622A8:00: Firmware info: version 2:0:0-b678a
[ 14.184460] sof-audio-acpi-intel-byt 808622A8:00: Firmware: ABI 3:20:0 Kernel ABI 3:23:0
snd_intel_dspcfg 36864 3 snd_sof,snd_sof_acpi_intel_byt,snd_intel_sst_acpi
snd_intel_sdw_acpi 20480 1 snd_intel_dspcfg
cfg80211 1241088 1 brcmfmac
@Jeremy YOU ARE THE GOAT! IT WORKS NOW!!! I'M SPEECHLESS, THANK YOU SOOOO MUCH!!!
