I upgraded to Kubuntu Trusty last summer, and now that I'm back in school, I've noticed that my laptop has been failing to connect to the school's wireless (which is a completely open network). Every time I try to connect, it says Connecting for a while, and then it fails with the error message:
IP configuration was unavailable
Or, if I play with the wireless setup (changing the driver, using direct commandline methods to connect to the network), then the error message changes:
Authorization supplicant timed out
which is weird, because there's no need to authenticate anything (it's an open network).
It's interesting, because I know that my current setup can connect to a wireless network, as it works perfectly fine at home (which, unlike the school network, is locked down), and it uses DHCP there as well.
I've tried running sudo dhclient wlan0, but nothing happens.
My wireless card is a Broadcom BCM4313, and I'm using the wl driver.
Any suggestions?
