I wanted to switch my main desktop over to Linux now. Everything works as intended except the wifi. I have the TP-Link Archer TBE550E and wondering if it is an easy fix for this. Or is it simply not gonna work?
I'm on Ubuntu 24.04.
I haven't looked far since I don't know what to look for. But as of what I saw graphic wise it's not there. so no wifi at all.
I have enabled onboard wifi now but would like to use the extension card since the onboard doesn't work when switching to Windows.
*-network UNCLAIMED
description: Network controller
product: MEDIATEK Corp.
vendor: MEDIATEK Corp.
physical id: 0
bus info: pci@0000:08:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm cap_list
configuration: latency=0
resources: memory:f5e00000-f5ffffff memory:f6000000-f6007fff
*-network
description: Ethernet interface
product: RTL8125 2.5GbE Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:0a:00.0
logical name: eno1
version: 05
serial: e8:9c:25:de:ce:da
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.8.0-40-generic firmware=rtl8125b-2_0.0.2 07/13/20 latency=0 link=no multicast=yes port=twisted pair
resources: irq:38 ioport:e000(size=256) memory:f6500000-f650ffff memory:f6510000-f6513fff
*-network
description: Wireless interface
product: RTL8852BE PCIe 802.11ax Wireless Network Controller
physical id: 0
bus info: pci@0000:0b:00.0
logical name: wlp11s0
version: 00
serial: a8:41:f4:2b:4a:e2
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtw89_8852be driverversion=6.8.0-40-generic firmware=N/A ip=10.0.0.9 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:110 ioport:d000(size=256) memory:f6400000-f64fffff
