I've been using Ubuntu on my laptop for about 8 months, and have never had a problem connecting to my home wireless network. But all of a sudden, I am unable to connect. I can see the network, and the system still automatically tries to connect, but it just keeps trying (unsuccessfully) to connect. I have taken a look at similar questions, but have not been able to solve the problem.
Note: I can still connect to other WiFi networks (like at school)
Any support is greatly appreciated!
Silly first steps
  1. Have you tried restarting your home router? I know this might be a silly comment but sometimes is just the router. Disconnect from the wall and reconnect if necessary.
  2. Verify that the password was not changed by a family member or friend. Might be as simple as that.
  3. Delete the connection...
Go to the network indicator (indicators are the icon applets in the top right: volume, network, clock/calendar, etc...):
Enter into Edit connections...
Select your home network on the list and press Delete.
Try to connect again entering the information as needed.
Still not working?
Let me know and will try to help further.
Torrien
  • 865
1st suggestion
Verify that password. Every one makes mistakes... fortunately, passwords have zero tolerance for mistakes :) Also, make sure the security type is correctly set (WPA, WPA2, WEP, etc.)
2nd suggestion
If you own other devices that ARE able to connect, check their gateway, subnet, IP, DNS information and try manually setting your laptop with the same information but w/a different IP. Verify there are no other devices on your network fighting over the same IP address. (If you don't own any other devices, hard wire your laptop with an ethernet cord and note the same information then manually set the WIFI connection)
3rd suggestion
You may have possibly installed another kernel during an update/upgrade that broke your wireless. First open up a terminal and type:
uname -r
Write down the output on paper or other device. Next, type:
dpkg --list | grep linux-image
If you see more than one kernel installed: reboot your computer, but keep pressing Shift as your computer is starting so you can get to your GRUB menu. From there, use the arrow buttons to select a different kernel (than the one you wrote down) to boot from and see if anything changes.
BTW
Do you administer your router?
Also,
Have you tried booting from a live cd/usb & trying to establish a WIFI connection?
I got this resolved by changing the channel on my WiFi router (in my case from channel 3 to 9). Funnily enough, after switching back to channel 3 again, Ubuntu could connect to the same WiFi on the old channel again. ¯_(ツ)_/¯
I got the solution from this answer: https://askubuntu.com/a/1177749/119592
Zoltán
  • 826
-1
For new readers: sometimes we ignore possible problems around ourselves(E.g. wrong password): make sure Access Control option is disable or modified on your router. or you can solve this problem by changing WiFi channel as mentioned before.
Bushida
  • 51
