I know this question can be redundant, but I have not been able to fix it and I am starting to be desperate. Busy at work and without time to fix it, I lose connection every 5-10 min, my hair is getting whiter...
So I changed the router, and that is the origin of the problem. I have a dual boot with Windows.
1) I checked if the connection was stable. In Windows it was.
2) I did the IPV6 thing (Change the wireless setting of IPv6).
3) I also tried this
echo "options iwlwifi 11n_disable=1" | sudo tee /etc/modprobe.d/iwlwifi.conf sudo modprobe -rfv iwldvm sudo modprobe -rfv iwlwifi sudo modprobe -v iwlwifi
4) Then I went for the best solution, following instructions here (Wifi Connection lost randomly)
But when I run this I get an error
echo "options RTL8111/8168/8411 fwlps=N" | sudo tee /etc/modprobe.d/RTL8111/8168/8411.conf
So now I do not know what to do next. I link (for being too long) information from wireless info script as recommended. http://paste.ubuntu.com/25024757/
Any other help, will be deeply appreciated.
I am writing this in order to hopefully help you and the inevitable searchers understand more about the process of identifying and correcting wireless problems. It is fruitless to blindly apply fixes found around the internet forums without verifying that your device is the same device referred to; either with lspci for internal devices or lsusb for USB devices. As you see, random fixes intended for devices other than your own are not ever helpful.
This is your wireless device:
ID 050d:2103 Belkin Components F7D2102 802.11n
And here are its drivers:
rtl8xxxu               73728  0
rtl8192cu              69632  0
rtl_usb                20480  1 rtl8192cu
rtl8192c_common        53248  1 rtl8192cu
rtlwifi                77824  3 rtl_usb,rtl8192c_common,rtl8192cu
mac80211              737280  4 rtl8xxxu,rtl_usb,rtlwifi,rtl8192cu
cfg80211              565248  2 mac80211,rtlwifi
I said driverS because there are two possibly conflicting drivers loaded. Let's blacklist one and see if connectivity improves. From the terminal:
sudo -i
echo "blacklist rtl8192cu"  >>  /etc/modprobe.d/blacklist.conf
exit
Reboot and tell us if conditions are improved.
chili555
  • 61,330
