My sister's computer can't access the internet. It just says "No Wi-Fi Adapter Found". After that it asks me to make sure the Wi-Fi adapter is plugged in/turned on. She was using Ubuntu 20.04, but installed Ubuntu 22.04 in the hopes of fixing it. It didn't fix it. I also tried running sudo lshw -class network command in the terminal. At first it says "usb", but then that disappears and is replaced with a new line. No output. When I run lsusb, it gives me the following output:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 04f2:b723 Chicony Electronics Co., Ltd HP TrueVision HD Camera
Bus 001 Device 002: ID 0bda:b00b Realtek Semiconductor Corp.
Realtek Bluetooth 4.2 Adapter
When I run: lspci --nnk | grep Net, there is no output.
