I'm having some issues with my wireless connection.
I'm using Ubuntu 12.04:
$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=12.04
DISTRIB_CODENAME=precise
DISTRIB_DESCRIPTION="Ubuntu 12.04.5 LTS"
Kernel Version:
$ uname -a
Linux dtabar-laptop 3.13.0-49-generic #81~precise1-Ubuntu SMP Wed Mar 25 16:32:15 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
The issue is with the bit rate, it's stuck between 1Mb/s and 6 Mb/s as you can see:
$ iwconfig
wlan0     IEEE 802.11abgn  ESSID:"NewSocrates"
          Mode:Managed  Frequency:2.462 GHz  Access Point: E8:DE:27:42:35:82
      Bit Rate=6 Mb/s   Tx-Power=15 dBm
      Retry  long limit:7   RTS thr:off   Fragment thr:off
      Power Management:off
      Link Quality=70/70  Signal level=-37 dBm
      Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
      Tx excessive retries:0  Invalid misc:116   Missed beacon:0
sudo lshw -class network output:
*-network
   description: Wireless interface
   product: Centrino Advanced-N 6205 [Taylor Peak]
   vendor: Intel Corporation
   physical id: 0
   bus info: pci@0000:03:00.0
   logical name: wlan0
   version: 34
   serial: 84:3a:4b:33:bf:5c
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
   configuration: broadcast=yes driver=iwlwifi driverversion=3.13.0-49-generic firmware=18.168.6.1 ip=192.168.0.105 latency=0 link=yes multicast=y es wireless=IEEE 802.11abgn  resources: irq:47 memory:f1c00000-f1c01fff
Anything I'm missing? Any ideas of what may be causing this?
Thanks!
Diego
It seems from the output of the wireless debugging script that your WiFi is sharing channel 11 with 6 other WiFi networks close to you.
Please go to your router and change the channel to 2 (currently unused by any of the WiFi networks around you). That will improve your throughput.
Fabby
  • 35,017
