I installed Ubuntu 24.04 on my PC a few moths ago and for these months the Wi-Fi was working fine.
I kept the PC off for a few days. Now that I have turned it back on the Wi-Fi is not working. If I open the Wi-Fi setting page I get the message "No Wi-Fi adapter found".
Following the script in this question I have gathered the wi-fi information here https://termbin.com/pnv0v
The system is updated (Ubuntu 24.04.1 LTS). The kernel version is Linux 6.8.0-51-generic.
I have already tried the following with no success (they were already installed):
sudo apt install linux-firmware
sudo apt install broadcom-sta-dkms
Any suggestion is welcome.
Mil
  • 601
Your log clearly shows that no WiFi hardware has been recognized. What puzzles me is this entry:
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
Here the iwlwifi driver is being removed - maybe because the system doesn't recognize your hardware anymore.
I had a similar case once and needed to install the linux-firmware packages:
Reboot and report back
Update
This is the information from your link:
Subsystem: ASUSTeK Computer Inc. BCM4352 802.11ac Dual Band Wireless Network Adapter [1043:855c]
Kernel modules: bcma, wl
Try this answer in hope that this package contains the bcma kernel module
kanehekili
  • 7,426
Just faced the similar issue. In my case the lack of Wi-Fi adapter appeared after the laptop was awaken from suspended state.
Simple multiple reboots didn't help, but cold boot fixed the problem (disconnecting power sources and [in case of Asus laptop] holding power button for 20 seconds).
Same thing happens with me. For me the fix was to downgrade linux-firmware from 20240318.git3b128b60-0ubuntu2.9 to 20240318.git3b128b60-0ubuntu2 by using
sudo apt install linux-firmware=20240318.git3b128b60-0ubuntu2 -y
Alpha
