I installed Ubuntu 14.04 LTS on an old Acer Aspire 3680 last night. Previous to the install everything worked fine. I was able to connect to Wifi. Since the install I have not been able to.
All I have done so far is this:
  • run software updates
  • opened terminal and ran lspci, which tells me that I have a Broadcom BCM4311 802.11b/g WLAN (rev 01)
Then I ran sudo lshw -C network. This is the output:
  *-network
       description: Ethernet interface
       product: 88E8038 PCI-E Fast Ethernet Controller
       vendor: Marvell Technology Group Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: eth0
       version: 14
       serial: 00:1b:24:4f:f0:2c
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm vpd msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 duplex=full ip=192.168.1.19 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:43 memory:44000000-44003fff ioport:2000(size=256)
  *-network
       description: Network controller
       product: BCM4311 802.11b/g WLAN
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:03:00.0
       version: 01
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: driver=wl latency=0
       resources: irq:17 memory:44500000-44503fff
I than ran rfkill list all. output:
0: acer-wireless: wireless LAN
soft blocked: no
hard blocked: no
At this point I'm thinking I'm just missing a driver, easy fix. But just to cover my bases I ran lsmod | grep acer. output:
acer_wmi               31735  0
sparse_keymap          13708  1 acer_wmi
wmi                    18673  1 acer_wmi
video                  18903  2 i915,acer_wmi
After checking the support site I came to find 2 possible drivers. I first tried installing linux-firmware-nonfree driver and rebooting. I was still unable to connect. when running the rfkill list all command it now showed soft blocked: yes.
At this point I reinstalled the OS preformed all of the aforementioned steps but this time installed the firmware-b43-installer. Now again after running the rfkill list all command I am once again soft blocked.
I am stuck. Can anybody help me?
David Foerster
  • 36,890
  • 56
  • 97
  • 151
You needn't blacklist acer-wmi.
Please get a temporary internet connection and open a terminal and do:
sudo apt-get update
sudo apt-get purge bcmwl-kernel-source
sudo apt-get install firmware-b43-installer
Reboot and your wireless should be working.
chili555
  • 61,330
I believe the following command will fix it but if not then post the output from the script that I asked for.
echo "blacklist acer-wmi" | sudo tee -a /etc/modprobe.d/blacklist.conf
Reboot
Wild Man
  • 8,327
