I installed lubuntu 20.04 from a live usb, dual boot with Windows 10. I don't know how I missed it it during installation, but both the live and installed version are unable to connect to wifi.
To be more specific, after boot, I get a notification that I was connected to a wifi, and clicking the connetion manager in the taskbar shows all available networks around correctly. However, after a few seconds, all wifis disappear, and nothing brings them back.
To me, the issue seem to be that wlo1 is disabled.
sudo lshw -C network
*-generic DISABLED
description: Wireless interface product: RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:02:00.0 logical name: wlo1 version: ff serial: 40:5b:d8:4d:3c:e1 width: 32 bits clock: 66MHz capabilities: bus_master vga_palette cap_list ethernet physical wireless configuration: broadcast=yes driver=rtw_pci driverversion=5.4.0-47-generic firmware=N/A latency=255 link=no maxlatency=255 mingnt=255 multicast=yes wireless=IEEE 802.11 resources: irq:157 ioport:3000(size=256) memory:a1200000-a120ffff
this can be confirmed with ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
   valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: wlo1: <BROADCAST,MULTICAST> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 40:5b:d8:4d:3c:e1 brd ff:ff:ff:ff:ff:ff
(state DOWN).
One solution I found online was sudo ip link set wlo1 up, however that either immidiatelly finishes executing and fixes nothing, or after a short waiting returns RTNETLINK answers: Operation already in progress.
In similar questions, I saw people asking for lspci -knn | grep Net -A3; rfkill list, so here it is:
02:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8822BE 802.11a/b/g/n/ac WiFi adapter [10ec:b822] (rev ff)
    DeviceName: WLAN
    Kernel driver in use: rtw_pci
    Kernel modules: rtwpci
 0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
 1: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
Thank you for your help!
This is a little embarrassing, but after another couple of days and restarts, the problem fixed itself. I still don't know what the problem was, since the only thing I changed is that moved closer to the wifi router (but now, even if I go to my original location, everything works fine).
The only advice I can give to people with the same issue is to take a look at this: My wireless/WiFi connection does not work. What information is needed to diagnose the issue? and to - unlike me - use the wireless info diagnostic script: https://github.com/UbuntuForums/wireless-info
