i installed 24.04 on my acer laptop. all networks in my home clearly show connectivity under system settings. when attempting to logon, authentication password required window appears. I entered the router password not connection. copy pasted password; no connection. I have wired connections. Searched for device in terminal per other articles. pci qualcomm atheros adapter appears in list; usb appears in list. please help. i need my laptop wireless for school and work. could not find driver.
I am having the same problem and have an open question. I have worked around it by manually entering IP address, netmask, gateway and dns server in the wireless connection settings (Settings>Network). You might also have to select the BSSID and MAC address. Manual configuration will get you up and running, but it is no fix.
Added: 2024-06-03
In my case the problem is being caused by apparmor. I have confirmed this by disabling the dhclient profile in /etc/apparmor.d/sbin.dhclient as follows:
cd /etc/apparmor.d
If there is no disable directory create it as follows:
sudo mkdir /etc/apparmor.d/disable
Create a link to the sbin.dhclient profile in the new disable directory:
sudo ln -s /etc/apparmor.d/sbin.dhclient /etc/apparmor.d/disable
The profile is currently loaded and so needs to be disabled:
sudo apparmor_parser -R /etc/apparmor.d/sbin.dhclient
Obviously this is not a permanent solution, and I know nothing about apparmor, so I will raise a more specific question about apparmor and how to modify the profile so that dhclient works correctly when called by NetworkManager.
