I am using a compaq presario cq43 laptop. Initially I installed Ubuntu 12.04 and was using a broadcom wireless sta driver(BC4313) for Wi-Fi. It was working well, then after three years I installed Ubuntu 14.04. I'm having trouble with wifi now.
It only connects sometimes. After going through the Ubuntu forum discussions, I found a remedy.
Step 1:
  • Go to additional driver under software update
  • Select proprietary driver for broadcom
  • If not selected and click
  • apply changes
Step 2:
  • sudo apt-get purge bcmwl-kernel-source
  • sudo apt-get install linux-firmware-nonfree
Step 3:
  • Reboot
Now the issue is every time I restart my laptop I have to run the above steps and after rebooting the Wi-Fi works fine.
I have updated all the headers and software through software updater using LAN connection.
########## wireless info START ##########
Report from: 11 Aug 2014 15:33 IST +0530
Script from: 04 Aug 2014 18:47 UTC +0000
##### release #####
Distributor ID: Ubuntu
Description:    Ubuntu 14.04 LTS
Release:    14.04
Codename:   trusty
##### kernel #####
Linux 3.13.0-32-generic #57-Ubuntu SMP Tue Jul 15 03:51:12 UTC 2014 i686 athlon i686 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop #####
Ubuntu
##### lspci #####
06:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10ec:8136] (rev 05)
    Subsystem: Hewlett-Packard Company Device [103c:3577]
    Kernel driver in use: r8169
07:00.0 Network controller [0280]: Broadcom Corporation BCM4313 802.11bgn Wireless Network Adapter [14e4:4727] (rev 01)
    Subsystem: Hewlett-Packard Company Device [103c:1795]
    Kernel driver in use: bcma-pci-bridge
##### lsusb #####
Bus 002 Device 002: ID 058f:a001 Alcor Micro Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
##### PCMCIA Card Info #####
##### rfkill #####
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: yes
1: hp-wifi: Wireless LAN
    Soft blocked: no
    Hard blocked: yes
2: hp-bluetooth: Bluetooth
    Soft blocked: no
    Hard blocked: yes
##### lsmod #####
hp_wmi                 13702  0
sparse_keymap          13708  1 hp_wmi
wmi                    18673  1 hp_wmi
b43                   356470  0
ssb                    51854  1 b43
brcmsmac              529837  0
cordic                 12518  1 brcmsmac
brcmutil               15066  1 brcmsmac
bcma                   42043  3 b43,brcmsmac
mac80211              546051  2 b43,brcmsmac
cfg80211              409394  3 b43,brcmsmac,mac80211
##### interfaces #####
auto lo
iface lo inet loopback
##### ifconfig #####
eth0      Link encap:Ethernet  HWaddr
          inet addr:192.168.0.100  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::461e:a1ff:fec5:b875/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:231 errors:0 dropped:0 overruns:0 frame:0
          TX packets:364 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:136089 (136.0 KB)  TX bytes:47961 (47.9 KB)
##### iwconfig #####
lo        no wireless extensions.
eth0      no wireless extensions.
wlan0     IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=off
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
##### route #####
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.0.1     0.0.0.0         UG    0      0        0 eth0
192.168.0.0     0.0.0.0         255.255.255.0   U     1      0        0 eth0
##### resolv.conf #####
nameserver 127.0.1.1
##### nm-tool #####
NetworkManager Tool
State: connected (global)
- Device: wlan0 ----------------------------------------------------------------
  Type:              802.11 WiFi
  Driver:            brcmsmac
  State:             unavailable
  Default:           no
  HW Address:
  Capabilities:
  Wireless Properties
    WEP Encryption:  yes
    WPA Encryption:  yes
    WPA2 Encryption: yes
  Wireless Access Points
- Device: eth0  [Wired connection 1] -------------------------------------------
  Type:              Wired
  Driver:            r8169
  State:             connected
  Default:           yes
  HW Address:
  Capabilities:
    Carrier Detect:  yes
    Speed:           100 Mb/s
  Wired Properties
    Carrier:         on
  IPv4 Settings:
    Address:         192.168.0.100
    Prefix:          24 (255.255.255.0)
    Gateway:         192.168.0.1
    DNS:             192.168.0.1
##### NetworkManager.state #####
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
WimaxEnabled=true
##### NetworkManager.conf #####
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### iw reg get #####
country 00:
    (2402 - 2472 @ 40), (3, 20)
    (2457 - 2482 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
    (2474 - 2494 @ 20), (3, 20), NO-OFDM, PASSIVE-SCAN, NO-IBSS
    (5170 - 5250 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
    (5735 - 5835 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
##### iwlist channels #####
lo        no frequency information.
eth0      no frequency information.
wlan0     13 channels in total; available frequencies :
          Channel 01 : 2.412 GHz
          Channel 02 : 2.417 GHz
          Channel 03 : 2.422 GHz
          Channel 04 : 2.427 GHz
          Channel 05 : 2.432 GHz
          Channel 06 : 2.437 GHz
          Channel 07 : 2.442 GHz
          Channel 08 : 2.447 GHz
          Channel 09 : 2.452 GHz
          Channel 10 : 2.457 GHz
          Channel 11 : 2.462 GHz
          Channel 12 : 2.467 GHz
          Channel 13 : 2.472 GHz
##### iwlist scan #####
wlan0     Interface doesn't support scanning : Network is down
lo        Interface doesn't support scanning.
eth0      Interface doesn't support scanning.
##### module infos #####
[b43]
filename:       /lib/modules/3.13.0-32-generic/kernel/drivers/net/wireless/b43/b43.ko
firmware:       b43/ucode9.fw
firmware:       b43/ucode5.fw
firmware:       b43/ucode16_mimo.fw
firmware:       b43/ucode15.fw
firmware:       b43/ucode14.fw
firmware:       b43/ucode13.fw
firmware:       b43/ucode11.fw
license:        GPL
author:         Rafał Miłecki
author:         Gábor Stefanik
author:         Michael Buesch
author:         Stefano Brivio
author:         Martin Langer
description:    Broadcom B43 wireless driver
srcversion:     42BAE2DB9BADE3E7ECA2CC0
alias:          bcma:m04BFid0812rev1Dcl*
alias:          bcma:m04BFid0812rev18cl*
alias:          bcma:m04BFid0812rev17cl*
alias:          bcma:m04BFid0812rev11cl*
alias:          ssb:v4243id0812rev10*
alias:          ssb:v4243id0812rev0F*
alias:          ssb:v4243id0812rev0D*
alias:          ssb:v4243id0812rev0C*
alias:          ssb:v4243id0812rev0B*
alias:          ssb:v4243id0812rev0A*
alias:          ssb:v4243id0812rev09*
alias:          ssb:v4243id0812rev07*
alias:          ssb:v4243id0812rev06*
alias:          ssb:v4243id0812rev05*
depends:        bcma,ssb,mac80211,cfg80211
intree:         Y
vermagic:       3.13.0-32-generic SMP mod_unload modversions 686
signer:         Magrathea: Glacier signing key
sig_key:        A7:FC:65:90:FC:4A:8D:85:9A:AE:BD:A2:CA:5D:D0:47:16:24:4F:A0
sig_hashalgo:   sha512
parm:           bad_frames_preempt:enable(1) / disable(0) Bad Frames Preemption (int)
parm:           fwpostfix:Postfix for the .fw files to load. (string)
parm:           hwpctl:Enable hardware-side power control (default off) (int)
parm:           nohwcrypt:Disable hardware encryption. (int)
parm:           hwtkip:Enable hardware tkip. (int)
parm:           qos:Enable QOS support (default on) (int)
parm:           btcoex:Enable Bluetooth coexistence (default on) (int)
parm:           verbose:Log message verbosity: 0=error, 1=warn, 2=info(default), 3=debug (int)
parm:           pio:Use PIO accesses by default: 0=DMA, 1=PIO (int)
parm:           allhwsupport:Enable support for all hardware (even it if overlaps with the brcmsmac driver) (int)
[ssb]
filename:       /lib/modules/3.13.0-32-generic/kernel/drivers/ssb/ssb.ko
license:        GPL
description:    Sonics Silicon Backplane driver
srcversion:     3DE188310F77C566C2E8CB3
alias:          pci:v000014E4d00004350sv*sd*bc*sc*i*
alias:          pci:v000014E4d0000432Csv*sd*bc*sc*i*
alias:          pci:v000014E4d0000432Bsv*sd*bc*sc*i*
alias:          pci:v000014E4d00004329sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004328sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004325sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004324sv*sd*bc*sc*i*
alias:          pci:v000014E4d0000A8D6sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004322sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004321sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004320sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004319sv*sd*bc*sc*i*
alias:          pci:v000014A4d00004318sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004318sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004315sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004312sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004311sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004307sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004306sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004301sv*sd*bc*sc*i*
depends:
intree:         Y
[brcmsmac]
filename:       /lib/modules/3.13.0-32-generic/kernel/drivers/net/wireless/brcm80211/brcmsmac/brcmsmac.ko
firmware:       brcm/bcm43xx_hdr-0.fw
firmware:       brcm/bcm43xx-0.fw
license:        Dual BSD/GPL
description:    Broadcom 802.11n wireless LAN driver.
author:         Broadcom Corporation
srcversion:     43D6897F7EB716081DF69BE
depends:        bcma,mac80211,brcmutil,cfg80211,cordic
intree:         Y
[brcmutil]
filename:       /lib/modules/3.13.0-32-generic/kernel/drivers/net/wireless/brcm80211/brcmutil/brcmutil.ko
description:    Broadcom 802.11n wireless LAN driver utilities.
srcversion:     E81EE4CBB6A7A689150D93D
depends:
intree:         Y
[bcma]
filename:       /lib/modules/3.13.0-32-generic/kernel/drivers/bcma/bcma.ko
license:        GPL
description:    Broadcom's specific AMBA driver
srcversion:     E41B811D88783DD5BC38565
alias:          pci:v000014E4d00004727sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004365sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004359sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004358sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004357sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004353sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004331sv*sd*bc*sc*i*
alias:          pci:v000014E4d0000A8D8sv*sd*bc*sc*i*
alias:          pci:v000014E4d00004313sv*sd*bc*sc*i*
alias:          pci:v000014E4d00000576sv*sd*bc*sc*i*
depends:
intree:         Y
##### module parameters #####
[b43]
allhwsupport: 0
bad_frames_preempt: 0
btcoex: 1
hwpctl: 0
hwtkip: 0
nohwcrypt: 0
pio: 0
qos: 1
verbose: 2
##### /etc/modules #####
lp
brcmsmac
brcmsmac
brcmsmac
brcmsmac
b43
b43
##### blacklists #####
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
blacklist b43
blacklist wl
blacklist b43
blacklist wl
blacklist b43
blacklist wl
blacklist b43
blacklist wl
blacklist b43
blacklist wl
##### udev rules #####
# PCI device 0x10ec:0x8136 (r8169)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
# PCI device 0x14e4:0x4727 (brcmsmac)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
##### dmesg #####
[   14.492780] bcma: bus0: Found chip with id 0x4313, rev 0x01 and package 0x08
[   14.492818] bcma: bus0: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x24, class 0x0)
[   14.492843] bcma: bus0: Core 1 found: IEEE 802.11 (manuf 0x4BF, id 0x812, rev 0x18, class 0x0)
[   14.492889] bcma: bus0: Core 2 found: PCIe (manuf 0x4BF, id 0x820, rev 0x11, class 0x0)
[   14.505581] bcma: bus0: Bus registered
[   14.617110] brcmsmac bcma0:0: mfg 4bf core 812 rev 24 class 0 irq 23
[   14.838616] ieee80211 phy0: registered radio enabled led device: brcmsmac-phy0:radio gpio: 243
[   15.165326] type=1400 audit(1407751129.533:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=350 comm="apparmor_parser"
[   15.175540] type=1400 audit(1407751129.545:5): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=350 comm="apparmor_parser"
[   19.718493] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  131.249919] brcmsmac bcma0:0: brcms_ops_bss_info_changed: qos enabled: false (implement)
[  131.249989] brcmsmac bcma0:0: brcms_ops_config: change power-save mode: false (implement)
[  131.250768] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  131.737890] usb 4-2: Direct firmware load failed with error -2
[  131.739884] Bluetooth: can't load firmware, may not work correctly
[  133.207205] wlan0: authenticate with
[  133.210575] wlan0: send auth to  (try 1/3)
[  133.238251] wlan0: send auth to  (try 2/3)
[  133.333829] wlan0: send auth to  (try 3/3)
[  133.432728] wlan0: authentication with  timed out
########## wireless info END ############
Wild Man
  • 8,327
Do:
sudo -i
echo "blacklist b43" >>  /etc/modprobe.d/blacklist.conf
echo "blacklist ssb" >>  /etc/modprobe.d/blacklist.conf
exit
gksudo gedit /etc/modules
Then leave only one brcmsmac and completely remove all instances of b43 save the file. You may have to install gksu, it is not installed by default any more.
Also it is showing a hardblock this usually means the wireless is turned of by a physical switch or a key combination like FN+F2. Reboot
Wild Man
  • 8,327
