I have a Dell Inspiron 5520, Ubuntu 16.04 installed. I have some issues with the wireless. Sometimes the network doesn't response and starts working again after network restart or disabling/enabling Wifi. But again it stops working once in a while.
The thing that I'm curious about is that the BCM model in lspci output is different from dmesg:
$ lspci | grep BCM
08:00.0 Network controller: Broadcom Corporation BCM43142 802.11b/g/n (rev 01)
$ dmesg | grep BCM
[ 2.350917] usb 2-1.5: Product: BCM43142A0
[ 3.325396] Bluetooth: hci0: BCM: chip id 70
[ 3.345871] Bluetooth: hci0: BCM (001.001.011) build 0000
[ 3.349485] bluetooth hci0: Direct firmware load for brcm/BCM.hcd failed with error -2
[ 3.349489] Bluetooth: hci0: BCM: Patch brcm/BCM.hcd not found
[ 3.442293] wlan0: Broadcom BCM4365 802.11 Hybrid Wireless Controller 6.30.223.248 (r487574)
As you can see it's BCM43142 in lspci and BCM4365 in dmesg. Could it be the cause of the problem?
UPDATE:
Response to Hölderlin comment:
$ lspci -nnk | grep -i network -A2
08:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
Subsystem: Dell Wireless 1704 802.11n + BT 4.0 [1028:0016]
Kernel driver in use: wl
$ dmesg | grep "wlan0\|wl"
[ 3.295548] wl: module license 'MIXED/Proprietary' taints kernel.
[ 3.297473] wl: module verification failed: signature and/or required key missing - tainting kernel
[ 3.517031] wl 0000:08:00.0 wlp8s0: renamed from wlan0
[ 4.290537] IPv6: ADDRCONF(NETDEV_UP): wlp8s0: link is not ready
[ 612.884636] ERROR @wl_dev_intvar_get : error (-1)
[ 612.884643] ERROR @wl_cfg80211_get_tx_power : error (-1)
[ 971.996317] ERROR @wl_dev_intvar_get : error (-1)
[ 971.996323] ERROR @wl_cfg80211_get_tx_power : error (-1)
[ 984.256990] ERROR @wl_dev_intvar_get : error (-1)
[ 984.256998] ERROR @wl_cfg80211_get_tx_power : error (-1)
[ 5536.445371] IPv6: ADDRCONF(NETDEV_UP): wlp8s0: link is not ready
UPDATE2:
Thanks to Hölderlin I could find out that there is no problem with BCM names and the device-ids are the same. On the other hand I could fix my wireless issues by updating its driver from here.
