Just got Ubuntu on another computer and I've never had this issue. On Windows Vista, (the operating system alongside Ubuntu) The internet works fine. But when I click on the icon in the top right, no Wireless Networks show up. I don't know tons about Ubuntu so be detailed in your replies and tell it to me like I know nothing. The help would much appreciated!
Output of ifconfig
eth0      Link encap:Ethernet  HWaddr 00:25:64:47:a6:62
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:18
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:461 errors:0 dropped:0 overruns:0 frame:0
          TX packets:461 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:35265 (35.2 KB)  TX bytes:35265 (35.2 KB)
How can I get it to connect to my Wi-fi?
Pilot6
  • 92,041
Do:
sudo apt-get update
sudo apt-get install firmware-b43-installer
Reboot
Wild Man
  • 8,327
You are missing your wireless driver. Just do the following: Connect your laptop to internet using the cable, open application called "Software & Updates", go to tab "Additional Drivers" and there select to use proprietary driver for your wireless card.
mmm3743
  • 348
Your wireless network card may not have native support on Ubuntu. Firstly check if Ubuntu can detect your network card by running the command lspci or lsusb depending on whether your network card is pci/usb based. It should show something like this:
04:00.0 Network controller: Qualcomm Atheros AR93xx Wireless Network Adapter (rev 01)
Now open the link below and check to see if your network card has support.
https://help.ubuntu.com/community/WifiDocs/WirelessCardsSupported
Also looking at ndiswrapper may also help as it allows Ubuntu to run Windows wireless driver
https://help.ubuntu.com/community/WifiDocs/Driver/Ndiswrapper
go to your terminal and type this command
$ gedit /etc/modprobe.d/blacklist.conf*
update:
add "sudo" at the beginning of the command above:
$ sudo gedit /etc/modprobe.d ......
then you want to find where it says:
#causes no end of confusion by creating unexpected network interfaces
blacklist eth[a number here]
and add a hashtag before the line like this:
#blacklist eth[a number here]
reboot your laptop, and you should be good
Viraj Shah
  • 133
