I'm no longer able to use Wifi on my lenovo thinkpad p1 after a recent update from Ubuntu (i think at least). And I'm desperately looking for some guidance if it's the chip or if it's a driver issue.
This is probably a duplicate of another question but all the other ones I've seen talk about either Realtek or a Qualcomm based wifi chip. Mine is the 9560 from Intel. And I'm seeing the following output within the script provided by: https://askubuntu.com/a/425205/972343
https://pastebin.ubuntu.com/p/7C2NvXxXKH/
And this is what i see when running dmesg | grep iwl
[    6.947040] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    7.022558] iwlwifi 0000:00:14.3: loaded firmware version 38.c0e03d94.0 op_mode iwlmvm
[    7.077003] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x318
[    7.319388] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[    7.319393] iwlwifi 0000:00:14.3: Not valid error log pointer 0x00000000 for Init uCode
[    7.319451] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x3, CPU2 Status: 0x240f
[    7.319455] iwlwifi 0000:00:14.3: Failed to start INIT ucode: -5
[    7.333073] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -5
And some additional information provided by lspci -v | grep Network
00:14.3 Network controller: Intel Corporation Wireless-AC 9560 [Jefferson Peak] (rev 10)
0a:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
I figured it out -- apparently I had activated an invisible airplane mode through one of the function keys.
Thanks to @MrOrgon who I found by accident while googling. His comment made me think: Could it really be that easy...
Ubuntu 18.04 / iwlwifi : recurrent problems, now Airplane Mode activated and impossible to remove after suspend
I had a similar problem once , can't remember if dmesg showed the board but .... The discovery process of a life- cd/usb found/reseted and activated the wifi board. I just started up the computer from usb and checked if the wifi was recognized after that I could reboot the computer and my old system was able to use the wifi board. as if a setting in the board had to be reset.
Good luck with it !
