Below is network adapter i see, but not able to use it
lspci -vvnn | grep -A 9 Network
03:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4360 802.11ac Wireless Network Adapter [14e4:4360] (rev 03)
    Subsystem: Apple Inc. BCM4360 802.11ac Wireless Network Adapter [106b:0134]
    Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0, Cache Line Size: 256 bytes
    Interrupt: pin A routed to IRQ 18
    Region 0: Memory at c1b00000 (64-bit, non-prefetchable) [size=32K]
    Capabilities: <access denied>
    Kernel modules: bcma, wl
Kunal
Apparently there is some workaround available: You'll first need to blacklist the b43 driver by adding a blacklist file to /etc/modprobe.d/b43.conf with the contents "blacklist b43". Then run update-initramfs -u and then install the bcmwl-kernel-source package. After a reboot your wireless device should be available.
https://bugs.launchpad.net/ubuntu/+source/ubuntu-drivers-common/+bug/2013236
