I was trying to burn an audio cd in Brasero in Ubuntu 11.10 64bit first and all it would do is let me burn an image file to the hard drive.
So after I had no luck with it I decided to try K3B. I installed it and ended up with the same result to only burn an image.
I have a new blank cdr in the drive but Ubuntu itself, K3B, and Brasero do not see the blank cdr in the drive. Which I assume is why I can't burn to it.This is a cd/dvd burner and I have had no problems with it seeing and burning dvds.
Is there any way I can figure out what the problem is? I tried the net for an answer and had no luck.
Thanks for any help on this issue.
Jorge Castro
  • 73,717
chest069
  • 117
I'm having the same problems. The problem only happens when more than 3.8 GB of data is being burned. It has become a real pain to reinstall cdrtools constantly, and there are an increasing number of tricks needed to make burning programs work. Big, big fail on the Debian/Ubuntu front...
The problem is with cdrkit ( wodim /genisoimage ) which doesn't handle large volumes of data very well. This is a problem dating back years and stemming from the replacement of cdrtools with the dysfunctional (and unmainained) cdrkit.
This is one of my biggest gripes with Debian/Ubuntu.
