I updated my Ubuntu to 11.10 a few hours ago and the screen brightness keeps going up to the maximum and down to the minimum all the time on it's own. Sometimes it stops for a few minutes. And when I try to set it myself manually or when a few minutes has passed, it starts up again. (I'm new in trying to fix my own problems, so I might not get the obvious things right away.)
I now restarted a couple of times and now I'm using a newer version of kernel and the brightness is now constantly down and can't be set manually.
My laptop is a Samsung N220. I bought it a little over a year ago. I still have Windows 7 Starter on it (it was originally on it), but I had Ubuntu put on it from the start.
Jorge Castro
  • 73,717
Agnes
  • 31
5 Answers5
sudo add-apt-repository ppa:voria/ppa
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install samsung-backlight
please note that in 13.04 that last command has changed to
sudo apt-get install samsung-tools
Tusitas
  • 31
The solution in this thread worked for me
http://forum.ubuntuusers.de/topic/bildschirmhelligkeit-bei-gnome-3-spinnt-rum/
kjs_nbg
Solution can be found at Linux on my Samsung. I use this on my N210 and it has fixed a back-light issue I was having. They also provide the 'Easy slow down manager' which gets the other hot keys to work.
Jargon
The backlight flickering is caused by bug 810093 and affect many, if not all, Samsung netbooks running Oneiric. There are few workarounds from which at least these two work:
A) Download and install 'samsung-laptop' package from Fortunato's Linux on my Samsung testing PPA. The fix isn't (at least it isn't mentioned in the changelog nor in the bug report) in the stable Linux on my Samsung PPA.
OR B) Disable the kernel module by adding:
blacklist samsung_laptop
to :
/etc/modprobe.d/blacklist.conf
and then reboot.
papukaija
  • 2,425
-1
Try putting this into the file /etc/rc.local:
setpci -s 00:02.0 F4.B=00
To set the brightness to maximum all the time. I don't know if it works for you but that did the charm for me.
