Whenever I try to connect to wifi (with my USB dongle Netgear WNA3100M) Ubuntu freezes. There is no problem with plugging in the USB dongle. I can even see what networks are available. If I try to connect with a wrong password it still works (but offcourse tells me that the password is wrong) but as soon as I try to connect with the proper password Ubuntu freezes immediately.
This is happening since I updated to a newer kernel version.
When I boot into an older kernel (4.4.0-62) everything works fine.
Output of lsb_release -a:
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.2 LTS
Release:    16.04
Codename:   xenial
Ouput of uname -a
Linux MyPCName 4.4.0-66-generic #87-Ubuntu SMP Fri Mar 3 15:29:05 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Output of sudo lshw -class network
*-network
   description: Ethernet interface
   product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:03:00.0
   logical name: enp3s0
   version: 06
   serial: 00:25:22:d9:35:b0
   capacity: 1Gbit/s
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
   configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168e-3_0.0.4 03/27/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
   resources: irq:36 ioport:e000(size=256) memory:d0004000-d0004fff memory:d0000000-d0003fff
*-network
   description: Wireless interface
   physical id: 1
   bus info: usb@2:5
   logical name: wlxa42b8c5e383e
   serial: a4:2b:8c:5e:38:3e
   capabilities: ethernet physical wireless
   configuration: broadcast=yes driver=rtl8192cu driverversion=4.4.0-66-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11bgn
output of lsusb
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 0846:9021 NetGear, Inc. WNA3100M(v1) Wireless-N 300 [Realtek RTL8192CU]
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 046d:0841 Logitech, Inc.
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 003: ID 145f:0176 Trust Isla Keyboard
Bus 008 Device 002: ID 046d:c03e Logitech, Inc. Premium Optical Wheel Mouse (M-BT58)
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Output of lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h Processor Root Complex
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] BeaverCreek [Radeon HD 6550D]
00:01.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G series]
00:10.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 03)
00:10.1 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 03)
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [IDE mode] (rev 40)
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 11)
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 11)
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 11)
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 11)
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 13)
00:14.1 IDE interface: Advanced Micro Devices, Inc. [AMD] FCH IDE Controller
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD] FCH Azalia Controller (rev 01)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 11)
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] FCH PCI Bridge (rev 40)
00:14.5 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 11)
00:15.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 0)
00:15.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 3)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 0 (rev 43)
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 6
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 5
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 7
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
Output of rfkill list all
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
Output of lsmod | grep rtl
rtl8192cu              69632  0
rtl_usb                20480  1 rtl8192cu
rtl8192c_common        53248  1 rtl8192cu
rtlwifi                77824  3 rtl_usb,rtl8192c_common,rtl8192cu
mac80211              737280  3 rtl_usb,rtlwifi,rtl8192cu
cfg80211              565248  2 mac80211,rtlwifi
Output of dpkg -l network-manager
||/ Naam                                          Versie                      Architectuur                Omschrijving
ii  network-manager                               1.2.6-0ubuntu0.16.04.1      amd64                       network management framework (daemon and userspace tools)
By the way, all output was generated with my usb-dongle inserted, but not connected to the Wifi-network.
Bazzz
For a while the solution was booting into the older kernel. But since kernel update 4.4.0-75-generic everything is working again.
So the current solution is updating the kernel to the latest version.
Bazzz
