I've recently installed Ubuntu 11.10 on my PC and I have a resolution problem.
My screen resolution is set at 640x480 (4:3) and I can't see right the whole screen, the windows or the icons. The problem is that it does not have other options in monitor->display so I can choose the right one, and I think that it can't detect my monitor - it says "unknown"(i have a desktop with pentium4, at 3Ghz, asus motherboard and an Nvidia GeForce graphic card).
xrandr: Failed to get size of gamma for output default Screen 0: minimum 320 x 240, current 640 x 480, maximum 640 x 480 default connected 640x480+0+0 0mm x 0mm 640x480 50.0* 320x240 51.0
lspci -v | grep VGA
VGA compatible controller: nVidia Corporation NV34 [GeForce FX 5200] (rev a1) (prog-if 00 [VGA controller]) Subsystem: PROLINK Microsystems Corp Device 1152 Flags: bus master, 66MHz, medium devsel, latency 248, IRQ 16 Memory at fd000000 (32-bit, non-prefetchable) [size=16M] Memory at e8000000 (32-bit, prefetchable) [size=128M] [virtual] Expansion ROM at fe9e0000 [disabled] [size=128K] Capabilities: <access denied> Kernel driver in use: nvidia Kernel modules: nvidia_173, nouveau, nvidiaf
