Why won't it run on my Thinkpad T42?
The command /usr/lib/nux/unity_support_test -p should print out specific information on exactly which graphics card feature is missing.
- 6,400
Probably (and most likely) it is not able to run on your hardware, and you should report a bug on unity. Unity is still in the early stages of development. Also, if you are running on open-source drivers, you may not be able to get the full experience (depending on your hardware again, but you don't say).
As an aside, this kind of question isn't likely to get a useful answer without a bit more information.
- 51,797
does compiz work fine in natty for you? unity have a few more requirements that usual compiz though it might have something to do with the fact that your laptop does not come in minimal system requirements https://wiki.ubuntu.com/DesktopExperienceTeam/UnityHardwareRequirements
- 182
Well I now have Ubuntu 11.10 on a Thinkpad t42 but unlike on previous versions of Ubuntu it automatically starts in 2d mode.If you are using an older version of Ubuntu you may like to try this guide.
It will be slight;ly different than Unity 3d but still works very well and the difference is limited mainly to being able to change icons positioning on the bar.
As it happens the T42 although a really useful and well buit machine has a relatively old Graphics card. Mine is the ATI 7500 and this does not work with the fglrx driver.
If you interested in boosting your T42 with Linux (as it runs really well ) I would also recommend the Thinkwiki site :
They have helped me as I hada Bios that needed updating and they had a really good guide to doing this with no Windows (although scarey it worked a dream!)
They also point to the problems with the ATI graphics card :
- 1,903
