I downloaded version 11.04 and it does not find the drivers to install and can not even find anything on google to fix this problem. thought I was my wireless did not work on linux, but I downloaded the Ubuntu version ultimate gamers, and my wireless worked normal I downloaded version 12.04, thinking it would fix q hitch, but then nothing = / Please give me a light. I can not stand to use another OS, I want Ubuntu!!!
Which wireless card are you using?
Reply with the output from the following command: lspci
- 21
If it's a broadcom wireless card then you will need to run the following to get wireless working.
sudo apt-get install firmware-b43-installer
- 131
I had a similar problem. In my case, it was working fine, but I had to reinstall Kubuntu (unrelated issue), and it wasn't working anymore. I fixed it like this (requires wired connection):
Go to System >> Additional Drivers.
Remove the Broadcom STA drivers.
Activate Broadcom STA drivers (will download and reinstall).
Problem solved.
- 119,640
- 11
Things helped me to enable wireless network:
My laptop: Vista, Compaq, UBUNTU 12.04
lshwreturned*-network UNCLAIMED- connected to wired network
- ran
sudo apt-get update; - Verified broadcom driver in "Additional Drivers". Wirless options are not yet available after this step.
lshwreturned*-network DISABLED.- ran sudo modprobe b43; At this point I was able to see the wireless options in the menu, but these options are not enabled. The light on wireless switch is amber.
- ran
echo b43 | sudo tee -a /etc/modules > /dev/null;still not wireless is not enabled. The light on wireless switch is amber. - ran
sudo apt-get install firmware-b43-installer;This turns the wireless light to blue and wireless options are available.
I have read many blogs. Each step here comes from a different blog. But finally worked. Thanks for everyone.
I am still wondering how did the wireless worked automatically when I ran Ubuntu from CD in recovery mode and why can't the install do the same! That would save a lot of time.
- 11
Connect to the internet on that computer with ethernet if possible and go to PREFERENCES >> ADDITIONAL DRIVERS
The driver for your wireless card should pop up if you are connected to the internet. Then just click INSTALL or ENABLE.(I forget what verbiage is used there)
- 1,351
