I dual-boot Ubuntu and Windows.
If I shutdown my PC, and then turn on and boot in Ubuntu, my USB wireless adapter does not initialize. I currently have 2 workaround:
  1. Unplug USB adapter, then plug in (while in Ubuntu session)
  2. Boot in Windows, which doesn't have this problem, then restart (without turning PC off) and boot in Ubuntu
I use mainly second option, but would appreciate real solution to this problem.
If I just reboot Ubuntu, without tuning PC off, then everything is fine
Here is update information:
$ lsusb
Bus 001 Device 002: ID 083a:4505 Accton Technology Corp. SMCWUSB-G 802.11bg
$ sudo lshw -class network
*-network
     description: Ethernet interface
     product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
     vendor: Realtek Semiconductor Co., Ltd.
     physical id: 0
     bus info: pci@0000:01:00.0
     logical name: eth0
     version: 02
     capacity: 100Mbit/s
     width: 64 bits
     clock: 33MHz
     capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
     configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
     resources: irq:40 ioport:e800(size=256) memory:fdeff000-fdefffff memory:fdee0000-fdeeffff memory:febe0000-febfffff
*-network
     description: Wireless interface
     physical id: 1
     bus info: usb@1:2
     logical name: wlan0
     capabilities: ethernet physical wireless
     configuration: broadcast=yes driver=zd1211rw driverversion=2.6.38-13-generic firmware=4725 link=yes multicast=yes wireless=IEEE 802.11bg
Second update:
I compared dmesg logs from successful init, and from init failure, and here is what seemed relevant to me:
First in both logs is line:
usb 1-2: new high speed USB device using ehci_hcd and address 2
which I assume is referencing this WLAN adapter, and then only in session that failed to init my wlan adapter:
hub 1-0:1.0: unable to enumerate USB device on port 2
usb 1-2: new high speed USB device using ehci_hcd and address 9
usb 1-2: new high speed USB device using ehci_hcd and address 17
usb 1-2: new high speed USB device using ehci_hcd and address 18
usb 1-2: new high speed USB device using ehci_hcd and address 19
usb 1-2: new high speed USB device using ehci_hcd and address 20
usb 1-2: new high speed USB device using ehci_hcd and address 22
usb 1-2: new high speed USB device using ehci_hcd and address 23
usb 1-2: new high speed USB device using ehci_hcd and address 27
usb 1-2: new high speed USB device using ehci_hcd and address 31
usb 1-2: new high speed USB device using ehci_hcd and address 32
usb 1-2: new high speed USB device using ehci_hcd and address 33
usb 1-2: new high speed USB device using ehci_hcd and address 37
usb 1-2: new high speed USB device using ehci_hcd and address 43
usb 1-2: new high speed USB device using ehci_hcd and address 44
usb 1-2: new high speed USB device using ehci_hcd and address 48
usb 1-2: new high speed USB device using ehci_hcd and address 49
usb 1-2: new high speed USB device using ehci_hcd and address 51
usb 1-2: new high speed USB device using ehci_hcd and address 57
usb 1-2: new high speed USB device using ehci_hcd and address 58
usb 1-2: new high speed USB device using ehci_hcd and address 65
usb 1-2: new high speed USB device using ehci_hcd and address 72
usb 1-2: new high speed USB device using ehci_hcd and address 78
usb 1-2: new high speed USB device using ehci_hcd and address 79
usb 1-2: new high speed USB device using ehci_hcd and address 84
usb 1-2: new high speed USB device using ehci_hcd and address 85
usb 1-2: new high speed USB device using ehci_hcd and address 86
usb 1-2: new high speed USB device using ehci_hcd and address 87
usb 1-2: new high speed USB device using ehci_hcd and address 89
usb 1-2: new high speed USB device using ehci_hcd and address 93
vlad
  • 175
