Since yesterday, when I upgraded Ubuntu to 11.10, I've had a very slow wifi connection. My route is a D-Link Dir 600. With Ubuntu Natty all worked fine. In fact on the same netbook, I have Linux mint 11 in another partition, and it works fine today. So I think is a problem between this router and kernel 3. Anyone have the same problem?
Thanks and greetings from Argentina!!!
PD     *-network
       description: Ethernet interface
       product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:05:00.0
       logical name: eth0
       version: 02
       serial: 60:eb:69:03:50:e0
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=N/A latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:42 ioport:2000(size=256) memory:f0520000-f0520fff memory:f0510000-f051ffff memory:f0540000-f055ffff
  *-network
       description: Wireless interface
       product: AR9285 Wireless Network Adapter (PCI-Express)
       vendor: Atheros Communications Inc.
       physical id: 0
       bus info: pci@0000:09:00.0
       logical name: wlan0
       version: 01
       serial: 1c:65:9d:21:f0:c4
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=ath9k driverversion=3.0.0-12-generic firmware=N/A ip=192.168.0.10 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
       resources: irq:18 memory:f0100000-f010ffff
belacqua
  • 23,540
Problem solved! After reading a lot, i decided to reset the router to the factory values, and to configure a new user and a new password. After that, the wifi connection runs very well on my Ubuntu 11.10, and in the other OS that i have in my house, like win7 or linux mint.
N.N.
  • 18,589
I had similar problem with Netgear WNR2000 router and AR9285; solved reducing router speed from 300 MBPS to 54 MBPS.
