I am facing the problem described in this thread and this thread.
To describe in brief, my internet wifi faces problem where the internet pages don't load every few minutes and completely stop working. However I see that sometimes the services like skype or even gmail are unaffected. During this time the wifi symbol is continuously says that wifi is connected!
The internet returns after sometime and then the story repeats. Important to note that wifi works perfectly fine with the Windows 7 (dual boot). I have also checked this at my friend's home where wifi has problem with Ubuntu but not with Windows.
I have come across this post discussing the similar problem. Need to try that. However any better/permanent solution is welcome.
Edit: I have tried with WICD as mentioned in other links. It doesn't appear to be a great improvement for now. I have found one more askubuntu link which I am yet to explore.
iammilind
  • 2,247
I had the same problem with my laptop (with a Broadcom b43 adapter) after installing 12.04. Then I googled and found the answer here. I don't remember the thread, but I don't deserve credit if you solve this problem thanks to my answer.
Make sure you have the wireless driver installed and enabled.
You may need proprietary/restricted drivers.
If you can connect via Ethernet follow these steps:
Connect to internet using an ethernet connection. It will be detected as ato eth0.
Click the settings icon on the launcher.
Go to Restricted drivers.
If you find your wireless card on the driver list, enable it. The driver will be downloaded and enabled.
Hope this helps.
