Suspend and Hibernate was not working in my Ubuntu 11.04 and I followed these instructions to fix the issue by installing uswsusp.
The commands s2ram and s2disk were working fine for me and hence I replaced the contents of hal-system-power-suspend-linux and hal-system-power-hibernate-linux as directed in the above link.
Now after my upgrade to Ubuntu 11.10, I am unable to hibernate my system. How to rectify this issue? Is there any config file which I need to change for hibernate to function properly?
Vivek
  • 3,829
Please make sure that your swap is mounted correctly. Edit the /etc/fstab/ file using the nano editor:
sudo nano /etc/fstab
When the /etc/fstab is opened, go to the line where you can read: ” # swap was on /dev/…..” immediately after this line, I mean the next line, be sure there is no ”#”. If there is a ”#” starting this following line, just delete it. Then press Ctrl+O and after that Enter to save the changes you made to fstab, then Ctrl+X to exit nano. Now your swap space will be active for hibernation after the next reboot.
sudo apt-get install uswsusp
...and restart your computer.
karel
  • 122,292
  • 133
  • 301
  • 332
