Recently I installed Ubuntu 12.10 alongside Windows in a separate partition with ext3 file format.
Everything worked fine when I installed 12.10 at first. But after I updated the packages (which was around 70mb), my Wifi connections aren't shown. I can see bluetooth working fine, but I cannot see any active Wireless connections (i have checked the "Enable networking" also).
Salem
  • 19,864
  • 65
  • 90
Ravi
  • 51
I had a similar problem, it was resolved by following the steps here
http://www.upubuntu.com/2012/10/how-to-fix-unity-and-wireless-problems.html
WiFi Stops Working After Upgrading To Ubuntu 12.10 (Broadcom Wireless cards)
You can fix wifi problems using two methods:
  • Either connect to the internet via wired connection and run this command:
    sudo apt-get update && sudo apt-get upgrade
Then reboot your system.
  • Or use the following commands:
    sudo apt-get install linux linux-headers-generic kernel-package
    sudo apt-get install --reinstall bcmwl* firmware-b43-lpphy-installer b43-fwcutter
Finally, reboot your system.
If that didn't help, try these commands:
sudo apt-get remove bcmwl-kernel-source
sudo apt-get install firmware-b43-installer b43-fwcutter
sudo reboot
Ringtail
  • 16,285
David
  • 141
