Hello I was running Ubuntu 10.04 on a desktop Dell Optiplex GX620 with onboard graphics Intel 82945g (945G), and even then I had to use xrandr to add mode 1280x1024 and edit the files in /etc/gdm, but it worked.
Support for Ubuntu version 10.04 is at an end and I was always getting reminders of it, so I downloaded ubuntu-12.04-desktop-i386.iso burnt the cd and did a clean install of ubuntu 12.04 not a distribution update, now maximum resolution is only 1024x768. I have updated the kernel now to version 3.5.0-10; however, there is no gdm folder in /etc, there is no xorg.conf file in /etc/X11 folder, and when I run xrandr I get the following:
jo@jo-Lin:~$ xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 640 x 480, current 1024 x 768, maximum 1024 x 768
default connected 1024x768+0+0 0mm x 0mm
   1024x768       61.0*
   800x600        61.0
   848x480         0.0
   640x480        60.0
When I run cvt I get this result:
jo@jo-Lin:~$ cvt 1280 1024
# 1280x1024 59.89 Hz (CVT 1.31M4) hsync: 63.67 kHz; pclk: 109.00 MHz
Modeline "1280x1024_60.00"  109.00  1280 1368 1496 1712  1024 1027 1034 1063 -hsync +vsync
Then I tried xrandr again several times:
jo@jo-Lin:~$ xrandr --newmode "1280x1024_60.00"  109.00  1280 1368 1496 1712  1024 1027 1034 1063 -hsync +vsync
jo@jo-Lin:~$ xrandr --addmode default 1280x1024_60.00
jo@jo-Lin:~$ xrandr --output default --mode 1280x1024_60.00
xrandr: screen cannot be larger than 1024x768 (desired size 1280x1024)
jo@jo-Lin:~$
Referring directly to your question, No. I am running 12.04 on a desktop right now.
The problem lies within your graphics drivers. First, consult your manual or computer specifications to find out whether your graphics card or graphics adapter is ATI(or AMD), nVidia, or Intel.Search for Terminal in the launcher. Then, type exactly and press enter:
sudo apt-get update
The next command will be run when you are again given a prompt. It will depend on what type of graphics card you have. If it is Intel, run:
sudo apt-get install mesa-utils
For nVidia:
sudo apt-get install nvidia-current
For ATI or AMD Vision:
sudo apt-get install flgrx
Let the command finish and then reboot.
Zanna
  • 72,312
nanofarad
  • 20,906
The solution for me was the following; The hardware Dell Optiplex GX620 desktop onboard graphics Intel 82945G (945G), Dell – E177FPc LCD monitor native mode 1280x1024 60Hz. I was running Ubuntu 10.10 and even then had to use xrandr to create and apply the 1280x1024 mode and edit /etc/gdm/Init/Default.
I downloaded Ubuntu-12.04-desktop-i386.iso burnt the CD, did a clean install, the graphics were fixed at 1024x768, did all the suggested updates updated the kernel to version 3.5.0-10 to no avail.
Read all the suggestions and recommendations in Ask Ubuntu, no change and when I opened Display in System settings it told me the monitor was a Laptop therein is the problem, and as we all know version 12.04 has no gdm folder in /etc, and no xorg.conf file but that is irrelevant as you will see.
What I did then was unplug the LAN cable booted up with the Ubuntu 10.10 CD and did a clean install used xrandr to create and apply the 1280x1024 mode and edit /etc/gdm/Init/Default, now everything was working resolution was 1280x1024, LAN cable still unplugged.
I then booted up with the Ubuntu 12.04 CD and proceed to do an installation, at the point where it detects that you have other operating systems and previous version of Ubuntu loaded and prompts you to select what you would like to do, I selected the option to Upgrade Ubuntu 10.10, it warns you that it will replace the system files but it will leave the users home folder in place, the installation was successful. When it rebooted and I logged in, it told me it could not apply 1280x1024 resolution CRTC310 in monitors.xml, I then used xrandr to create and apply the 1280x1024 resolution mode and created the .xprofile file in the home folder with the settings used to configure xrandr and rebooted.
All working in 1280x1024 mode there is now no gdm folder and still no xorg.conf file, when I go to System Settings, Displays it says Unknown not Laptop, I have plugged in the LAN cable and have installed some updates, it seems satisfactory, I will now run more updates and see what happens.
I had the very same problem, I was using a I-INC monitor that has 1 VGA & HDMI port. I was hooked to my GX620 via VGA cable with a "VGA to DVI convertor". In xrandr it was not detected as DVI, but as VGA instead. So I then put a "HDMI to DVI convertor" on a HDMI cable. Rebooted into a perfect HD resolution.
I had this problem with: ubuntu, linux mint, crunchbang linux, kali linux
The cable switch fixed the issue no problem on all distros.
Anyway...hope this helps those who might have the right convertors and cables lying around.
Xilas
