I am trying to enable compiz on my laptop via Desktop Effects but it does not allow it. I modified the xorg.conf file as on the compiz wiki but still no luck.
So can someone just tell me how to enable compiz desktop on an Intel i5 based system. This is an Arrandale processor so its got the graphics bit on the processor itself. My system also has a discrete graphics card (Nvidia GT330M - yup its those hybrid graphics combos n- not Optimus). As far as i know the nvidia gpu is not being used since the intel one is enabled and there is no bios route to disable it. The laptop is a Dell Vostro 3700 with bios version A10
I did lotsa google searches about intel compiz, etc but not a single conclusive guide as to how to enable it. so my guess is it should work out of the box. but it doesn't.
glxinfo
gives me:
name of display: :0.0
Xlib:  extension "GLX" missing on display ":0.0".
Error: couldn't find RGB GLX visual or fbconfig
3 GLXFBConfigs:
   visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
 id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
Segmentation fault
lsbusb gives me:
00:02.0 VGA compatible controller [0300]: Intel Corporation Core Processor Integrated Graphics Controller [8086:0046] (rev 18) 01:00.0 VGA compatible controller [0300]: nVidia Corporation GT216 [GeForce GT 330M] [10de:0a29] (rev a2)
Jorge Castro
  • 73,717
gontadu
  • 862
I managed to get compiz to work. i uninstalled nvidia's proprietary driver (nvidia-current). now with nouveau, glxinfo gives decent output and says direct rendering is enabled (turns out its talking about the intel chip). then i go to desktop effects, and when i select extra, it says install nvidia proprietary drivers, i click cancel, the screen blinks but compiz is now enabled
Ubuntuforums solution
gontadu
  • 862
Try to install bumblebee to have both the Intel and Nvidia cards working simultaneously: https://launchpad.net/~hybrid-graphics-linux
sudo apt-get install git
# type password
git clone http://github.com/MrMEEE/bumblebee.git
cd bumblebee/
sudo ./install.sh
optirun glxgears
# check the speed and compare to running:
glxgears
# If you have google-chrome installed, you can try it with/without optirun and report the FPS values on the mailing list:
optirun google-chrome http://webglsamples.googlecode.com/hg/aquarium/aquarium.html
719016
  • 6,467
Like peopple pointed you might be running a nvidia card. Did you try to install the nvidia proprietary driver?
