I have two monitors which where recognized in Ubuntu 12.04 after the installation was completed but now, after installing the ATI driver, one of my monitors is shown as "Laptop". Everytime I try to switch "Mirror displays" off I get an error saying that the resolution is not supported.
Asked
Active
Viewed 7,759 times
Since you installed the proprietary ATI driver, you have to use the tool AMDCCLE to configure your monitors. Just search "AMD" in the dash, and then you can change the resolution there.
jrg
- 61,707
In order to mirror displays, they must both support any one resolution. Set both monitors to the highest common resolution, and then try to mirror the displays again. However, the highest common resolution may be as low as 800x600 or even 640x480, which is not a good resolution for easily using newer versions of Ubuntu.
nanofarad
- 20,906
