I changed to Ubuntu 14.04 in this Compaq Presario V2000, but the wireless device (PCI) does not work. I already installed the drivers using ndiswrapper. But it still does not work.
What do I need to do to fix this problem?
You likely have Broadcom chip, confirm this with
lspci -vvnn
and look for the "Network controller" section, then find the chip on the first line after the {14e4,...) See http://wireless.kernel.org/en/users/Drivers/b43 for the correct driver, but it's probably b43. These days, the b43 driver works fine after you add the firmware, so add package linux-firmware-nonfree for any chip other than a 4306 rev before 3 For the older 4306 revs, use the b43legacy driver. Uninstall any ndiswrapper or other Broadcom drivers, and things should work.
