I installed Ubuntu Core 14.04 AMD 64. Now I want to play an audio! What exactly should be installed?! (I got this message on webkitgtk: jack server is not running or cannot be started)
I got this by run "lshw -short" command:
H/W path      Device      Class       Description
                          system      VirtualBox ()
/0                        bus         VirtualBox
/0/0                      memory      128KiB BIOS
/0/1                      memory      490MiB System memory
/0/2                      processor   Intel(R) Core(TM) i5 CPU       M 460  @ 2.53GHz
/0/100                    bridge      440FX - 82441FX PMC [Natoma]
/0/100/1                  bridge      82371SB PIIX3 ISA [Natoma/Triton II]
/0/100/1.1                storage     82371AB/EB/MB PIIX4 IDE
/0/100/2                  display     VirtualBox Graphics Adapter
/0/100/3      eth0        network     82540EM Gigabit Ethernet Controller
/0/100/4                  generic     VirtualBox Guest Service
/0/100/5                  multimedia  82801AA AC'97 Audio Controller
/0/100/6                  bus         KeyLargo/Intrepid USB
/0/100/7                  bridge      82371AB/EB/MB PIIX4 ACPI
/0/100/b                  bus         82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller
/0/3          scsi0       storage
/0/3/0.0.0    /dev/sda    disk        10GB VBOX HARDDISK
/0/3/0.0.0/1  /dev/sda1   volume      3812MiB EXT4 volume
/0/4          scsi1       storage
/0/4/0.0.0    /dev/cdrom  disk        DVD reader
I'm assuming you have some embedded board and intend to plug in some USB Audio Class device to have it play audio?
JACK is a sound server that can be installed with the jackd package, if you didn't know that already.
Note that JACK is intended for professionals. If you didn't use JACK before and just want to play audio similar to what is used in the Ubuntu Desktop releases you should have a look at the alsa-base and probably pulseaudio packages to get things started (be aware of the dependencies that are being pulled in!).
The error message requiring "jack server" may just be misleading, as most applications should work fine with PulseAudio or ALSA alone.
LiveWireBT
  • 29,597
Finally, I solved it!
We need only the alsa-base and gstreamer0.10-alsa packages.
Seth
  • 59,332
