I have Toshiba Portege M400 Tablet PC with Intel 82573L Gigabit Ethernet Controller. It works fine with Windows, but in Ubuntu it doesn't work!
During startup CMOS shows the following:
PXE-E05 error, LAN Adapter configuration not initialized, Boot Agent cannot continue.
I figured out that it was due to NVM Checksum error, and I tried to flash EEPROM using Intel Boot Utility with no success. Flashing EEPROM always returned the following error:
PXE not flashed on port 1, Firmware not present.
I restored to Kernel to edit driver files and bypass NVM Checksum error again to lure without any fruitful outcome.
Here are some terminal output:
$ lspci -v | grep 82573L
02:00.0 Ethernet controller: Intel Corporation 82573L Gigabit Ethernet Controller
$ ifconfig -a
just listed wlan0 only
Jorge Castro
  • 73,717
Touseef
  • 334
Finally I got the solution. I just skipped the NVM Checksum at Ubuntu startup by editing the device drivers of my Ethernet Controller (82573L gigabit).
Here are the steps:
  1. Download latest e1000e drivers from Intel site
  2. Decompress the source as follows
    tar zxvf e1000e-[VERSION].tar.gz
    cd e1000e-[VERSION]/src
  3. Open netdev.c and search for the following code and delete it:
    /* make sure the NVM is good */
    if(e1000_validate_nvm_checksum(hw) < 0)
        dev_err(pci_dev_to_dev(pdev), "The NVM Checksum Is Not Valid\n");
        err = -EIO;
        goto err_eeprom;
  4. Now run these commands:
    sudo modprobe -r e1000e
    sudo make install
    sudo modprobe e1000e
    sudo update-initramfs -u
    This will replace the old drivers and initialize these drivers at startup.
Note: The best way to correct the checksum error is to flash the EEPROM, but in my Case EEPROM was corrupted and wouldn't flash. So, I had to skip the Checksum Error Checkup at startup.
Aditya
  • 13,616
Touseef
  • 334
