I am a new Ubuntu user, I had enough problems with Windows always crashing.
So yesterday I installed Ubuntu 12.04 on my laptop.
I have an Acer Aspire 5942g, everything is running smoothly except I cannot get the wireless to work at all. The terminal stuff is new to me, I'd appreciate any suggestions.
Obs.: I have looked at some forums/posts on the wireless issue, however none have resolved mine.
Hope you guys can help me. Thanks.
Zignd
  • 10,982
Ubuntu normally allow you to easily connect to wireless networks by just clicking the name of the network you'd like to use, but most wifi cards need a proprietary driver to work. So check on the top bar if you have a notification to install additional drivers or go to the "System Settings" > "Additional Drivers" to see if you need to install a proprietary driver for your wifi card.
If new drivers have to be downloaded, you'll need a wired connection to the internet before being able to use your wireless connection.
If no drivers is needed you will be able to see a wireless icon on you top bar of your desktop, so just click on it to see the available wifi networks around you, if you can't see your network, click on "More networks" and if your network is hidden, click on "Connect to Hidden Wireless Network..." and give the information it will ask you.
This answer is an adapted transcription of the following YouTube video: http://www.youtube.com/watch?v=NJvB97cmrWk
Zignd
  • 10,982
I found when putting Ubuntu on my laptop it automatically shut off my wireless so if you have a quick button for that try pressing it. Second if you haven't tried it go to System Settings > Network > Wireless and make sure it's turned on. It should just take some online searching if that doesn't work. Make sure you've run the updates.
Just from a little search from the answers try
sudo iwconfig
That will tell you the status of your wired and wireless connections.
I also found this http://ubuntuforums.org/showthread.php?t=2035902&page=3 It's solved. Just make sure it applies to you and that you understand what each step is doing.
