I have installed Ubuntu 12.04 on Dell Vostro 1520 Laptop. But found Wifi is hardware locked, though wifi is working perfectly fine with Windows 7 in the same laptop.
I tried to upgrade the drivers as mentioned in other posts/forums but could not resolve the issue.
I had the similar problem with versions 11.* as well. Last time the Wifi worked with 10.* version.
Please help me to get it resolved.
user65696
  • 61
I have a Vostro 1520 on which I just upgraded to 12.04. Even though my wifi was working on 10.04, I have to re-do what I've done on 10.04... Here it is:
sudo rmmod dell_laptop
At this point, wireless indicator will light up and after a while, you'll be able to connect to the available wi-fi access points. However, the dell_laptop kernel module will get loaded again on bootup and hence, the fix is not permanent. Let's make it so:
echo 'blacklist dell_laptop' | sudo tee /etc/modprobe.d/blacklist-custom
Wireless should be working fine from now on.
It did on my laptop.
Hope this helps!
Eliah Kagan
  • 119,640
EricP
I had a hard time making the WiFi work after installing Ubuntu 12.10 on Dell XPS. Running rfkill list all always returned:
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: yes
After trying almost everyone of the tons of suggestions about this problem on the Ubuntu forums, and none of them worked form, I simply tried Fn+F2 (the F2 key has the WiFi sign) and the problem disappeared.
The simple solution (unless you have a deeper problem) is Fn+F2 (or whatever key with the WiFi sign).
BuZZ-dEE
  • 14,533
momusa
I also faced the same problem when upgraded to 11.10. I tried the auto updating using the hard line -ethernet cable - , but didn't work. After some research I finally made it. In the end, these commands made my day.
To make this work, your must be connected to Internet, so use LAN cable.
sudo apt-get purge bcmwl-kernel-source broadcom-sta-common broadcom-sta-source
sudo apt-get install b43-fwcutter firmware-b43-installer
Then reboot.
