I got cheap Ebay wifi dongle from HongKong, Im trying to set it up on my ubuntu server.
Occasionally need to move server, so it cannot always be connected to router via lan.
Anyhow, usb wifi came with a driver cd. I uploaded files to my home directory and tried to run install script (RTL 8188cus): sudo bash install.sh
But I get error:
Authentication requested [root] for make driver:
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/2.6.38-8-server/build M=/home/minime/RTL 8188cus/Linux/driver/rtl8192CU_linux_v2.0.1324.20110126 modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.38-8-server'
make[1]: *** No rule to make target `8188cus/Linux/driver/rtl8192CU_linux_v2.0.1324.20110126'. Stop.
make[1]: Leaving directory `/usr/src/linux-headers-2.6.38-8-server'
make: *** [modules] Error 2
Compile make driver error: 2, Please check error Mesg
Any ideas what Im doing wrong?
There is another driver folder for linux called: RTL 81XX, which doesn't have install.sh at all! I tried to use make command, but I get:
make: *** No targets specified and no makefile found. Stop.
Any help? this is first time I'm installing driver from source.
Im on Ubuntu 11.04 server.
lsusb
Bus 001 Device 002: ID 0bda:8176 Realtek Semiconductor Corp.
lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation N10 Family DMI Bridge [8086:a000] (rev 02)
00:02.0 VGA compatible controller [0300]: Intel Corporation N10 Family Integrated Graphics Controller [8086:a001] (rev 02)
00:1b.0 Audio device [0403]: Intel Corporation N10/ICH 7 Family High Definition Audio Controller [8086:27d8] (rev 02)
00:1c.0 PCI bridge [0604]: Intel Corporation N10/ICH 7 Family PCI Express Port 1 [8086:27d0] (rev 02)
00:1d.0 USB Controller [0c03]: Intel Corporation N10/ICH 7 Family USB UHCI Controller #1 [8086:27c8] (rev 02)
00:1d.1 USB Controller [0c03]: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 [8086:27c9] (rev 02)
00:1d.2 USB Controller [0c03]: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 [8086:27ca] (rev 02)
00:1d.3 USB Controller [0c03]: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 [8086:27cb] (rev 02)
00:1d.7 USB Controller [0c03]: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller [8086:27cc] (rev 02)
00:1e.0 PCI bridge [0604]: Intel Corporation 82801 Mobile PCI Bridge [8086:2448] (rev e2)
00:1f.0 ISA bridge [0601]: Intel Corporation NM10 Family LPC Controller [8086:27bc] (rev 02)
00:1f.2 IDE interface [0101]: Intel Corporation N10/ICH7 Family SATA IDE Controller [8086:27c0] (rev 02)
00:1f.3 SMBus [0c05]: Intel Corporation N10/ICH 7 Family SMBus Controller [8086:27da] (rev 02)
01:00.0 Ethernet controller [0200]: Atheros Communications Device [1969:1083] (rev c0)
sudo lshw
description: Desktop Computer
product: To Be Filled By O.E.M. (To Be Filled By O.E.M.)
vendor: To Be Filled By O.E.M.
version: To Be Filled By O.E.M.
serial: To Be Filled By O.E.M.
width: 64 bits
capabilities: smbios-2.6 dmi-2.6 vsyscall64 vsyscall32
configuration: boot=normal chassis=desktop family=To Be Filled By O.E.M. sku=To Be Filled By O.E.M. uuid=00020003-0004-0005-0006-000700080009
*-core
description: Motherboard
product: AD525PV3
vendor: ASRock
physical id: 0
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: P1.20
date: 04/01/2011
capacity: 448KiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb ls120boot zipboot biosbootspecification netboot
*-cpu
description: CPU
product: Intel(R) Atom(TM) CPU D525 @ 1.80GHz
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: Intel(R) Atom(TM) CPU D525 @ 1.80GHz
slot: CPUSocket
capacity: 1800MHz
width: 64 bits
clock: 200MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx constant_tsc arch_perfmon pebs bts rep_good nopl aperfmperf pni dtes64 monitor ds_cpl tm2 ssse3 cx16 xtpr pdcm movbe lahf_lm
configuration: cores=2 enabledcores=2 threads=4
*-cache:0
description: L1 cache
physical id: 5
slot: L1-Cache
capacity: 48KiB
capabilities: internal write-back data
*-cache:1
description: L2 cache
physical id: 6
slot: L2-Cache
capacity: 1MiB
capabilities: internal write-back unified
*-memory
description: System Memory
physical id: c
slot: System board or motherboard
*-bank:0
description: SODIMM DDR2 Synchronous 800 MHz (1.2 ns)
product: ModulePartNumber00
vendor: Manufacturer00
physical id: 0
serial: SerNum00
slot: DIMM0
width: 64 bits
clock: 800MHz (1.2ns)
*-bank:1
description: DIMM [empty]
product: ModulePartNumber01
vendor: Manufacturer01
physical id: 1
serial: SerNum01
slot: DIMM1
*-pci
description: Host bridge
product: N10 Family DMI Bridge
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 02
width: 32 bits
clock: 33MHz
configuration: driver=agpgart-intel
resources: irq:0
*-display
description: VGA compatible controller
product: N10 Family Integrated Graphics Controller
physical id: 2
bus info: pci@0000:00:02.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:41 memory:fea80000-feafffff ioport:dc00(size=8) memory:e0000000-efffffff memory:fe900000-fe9fffff
*-multimedia
description: Audio device
product: N10/ICH 7 Family High Definition Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 02
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=HDA Intel latency=0
resources: irq:43 memory:fea78000-fea7bfff
*-pci:0
description: PCI bridge
product: N10/ICH 7 Family PCI Express Port 1
physical id: 1c
bus info: pci@0000:00:1c.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:40 ioport:e000(size=4096) memory:feb00000-febfffff ioport:80000000(size=2097152)
*-network
description: Ethernet interface
product: Atheros Communications
vendor: Atheros Communications
physical id: 0
bus info: pci@0000:01:00.0
logical name: eth0
version: c0
serial: XX
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vpd bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=atl1c driverversion=1.0.1.0-NAPI duplex=full firmware=N/A ip=192.168.1.99 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:42 memory:febc0000-febfffff ioport:ec00(size=128)
*-usb:0
description: USB Controller
product: N10/ICH 7 Family USB UHCI Controller #1
physical id: 1d
bus info: pci@0000:00:1d.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: uhci bus_master
configuration: driver=uhci_hcd latency=0
resources: irq:23 ioport:d880(size=32)
*-usb:1
product: N10/ICH 7 Family USB UHCI Controller #2
physical id: 1d.1
bus info: pci@0000:00:1d.1
version: 02
width: 32 bits
clock: 33MHz
resources: irq:19 ioport:d800(size=32)
*-usb:2
product: N10/ICH 7 Family USB UHCI Controller #3
physical id: 1d.2
bus info: pci@0000:00:1d.2
version: 02
width: 32 bits
clock: 33MHz
resources: irq:18 ioport:d480(size=32)
*-usb:3
product: N10/ICH 7 Family USB UHCI Controller #4
physical id: 1d.3
bus info: pci@0000:00:1d.3
version: 02
width: 32 bits
clock: 33MHz
resources: irq:16 ioport:d400(size=32)
*-usb:4
product: N10/ICH 7 Family USB2 EHCI Controller
physical id: 1d.7
bus info: pci@0000:00:1d.7
version: 02
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci_hcd latency=0
resources: irq:23 memory:fea77c00-fea77fff
*-pci:1
product: 82801 Mobile PCI Bridge
physical id: 1e
bus info: pci@0000:00:1e.0
version: e2
width: 32 bits
clock: 33MHz
capabilities: pci subtractive_decode bus_master cap_list
*-isa
description: ISA bridge
product: NM10 Family LPC Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration: latency=0
*-ide
description: IDE interface
product: N10/ICH7 Family SATA IDE Controller
physical id: 1f.2
bus info: pci@0000:00:1f.2
logical name: scsi0
version: 02
width: 32 bits
clock: 66MHz
capabilities: ide pm bus_master cap_list emulated
configuration: driver=ata_piix latency=0
resources: irq:19 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:ff90(size=16) memory:80200000-802003ff
*-disk
description: ATA Disk
product: WDC WD10TPVT-11U
vendor: Western Digital
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 01.0
serial: WD-WXC1A80P0314
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 signature=00088c47
*-volume:0
description: EXT4 volume
vendor: Linux
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
logical name: /media/private
version: 1.0
serial: 042daf2d-350c-4640-a76a-4554c9d98c59
capacity: 300GiB
capabilities: primary journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
configuration: created=2011-11-06 11:05:03 filesystem=ext4 label=Private lastmountpoint=/media/private modified=2012-04-13 20:01:16 mount.fstype=ext4 mount.options=rw,relatime,barrier=1,stripe=1,data=ordered mounted=2012-04-13 20:01:16 state=mounted
*-volume:1
description: Extended partition
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
capacity: 625GiB
capabilities: primary extended partitioned partitioned:extended
*-logicalvolume:0
description: Linux filesystem partition
physical id: 5
logical name: /dev/sda5
logical name: /media/storage
capacity: 600GiB
configuration: mount.fstype=ext4 mount.options=rw,relatime,barrier=1,stripe=1,data=ordered state=mounted
*-logicalvolume:1
physical id: 6
logical name: /dev/sda6
logical name: /media/dropbox
capacity: 24GiB
*-volume:2
vendor: Linux
physical id: 3
bus info: scsi@0:0.0.0,3
logical name: /dev/sda3
logical name: /media/www
version: 1.0
serial: 9b0a27b4-05d8-40d5-bfc7-4aeba198db7b
capacity: 2570MiB
configuration: created=2011-11-06 11:05:11 filesystem=ext4 label=www lastmountpoint=/media/www modified=2012-04-15 11:31:12 mount.fstype=ext4 mount.options=rw,relatime,barrier=1,stripe=1,data=ordered mounted=2012-04-15 11:31:12 state=mounted
*-volume:3
description: Linux swap volume
physical id: 4
bus info: scsi@0:0.0.0,4
logical name: /dev/sda4
version: 1
serial: 6ed1130e-3aad-4fa6-890b-77e729121e3b
capacity: 4098MiB
capabilities: primary nofs swap initialized
configuration: filesystem=swap pagesize=4096
*-serial UNCLAIMED
description: SMBus
product: N10/ICH 7 Family SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 02
width: 32 bits
clock: 33MHz
resources: ioport:400(size=32)
*-scsi
physical id: 1
bus info: usb@1:4
logical name: scsi2
capabilities: emulated scsi-host
configuration: driver=usb-storage
*-disk
description: SCSI Disk
physical id: 0.0.0
bus info: scsi@2:0.0.0
logical name: /dev/sdb
configuration: signature=000b4c55
*-volume
vendor: Linux
physical id: 1
bus info: scsi@2:0.0.0,1
logical name: /dev/sdb1
logical name: /
version: 1.0
serial: 33926e39-4685-4f63-b83c-f2a67824b69a
capacity: 3862MiB
capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
configuration: created=2011-10-11 14:03:46 filesystem=ext4 lastmountpoint=/ modified=2012-03-19 11:47:29 mount.fstype=ext4 mount.options=rw,noatime,errors=remount-ro,barrier=1,data=ordered mounted=2012-04-15 11:31:11 state=mounted
rfkill list all Doesnt show anything!
dmesg | grep -i firmware
[ 0.715481] pci 0000:00:1f.0: [Firmware Bug]: TigerPoint LPC.BM_STS cleared
