I installed a fresh install of Ubuntu 12.10 and this is my first Ubuntu install. I have a Dell Inspiron 6400 and my wifi is turned off and cant seem to switch it on. I searched a lot on it but can only find answers for Ubuntu 12.04 :( can someone help me please? Thanks in advance
Jorge Castro
  • 73,717
I have the same problem and this was printed:
lo        no wireless extensions.
eth0      no wireless extensions.
The main problem was that I didn't check the "Install third party stuff" when my Ubuntu was installing. So I ran the following command:
sudo software-properties-gtk
Went to Additional Drivers tab and checked to use any proprietary driver I want.
Source: http://www.upubuntu.com/2012/10/to-do-list-after-new-installation-of.html
Murilo
  • 121
I had the same issue and this is what worked for me:
sudo apt-get remove bcmwl-kernel-source
sudo apt-get purge bcmwl-kernel-source
sudo apt-get install linux-firmware-nonfree
Source: http://catlingmindswipe.blogspot.com/2012/07/broadcom-wireless-fix-for-ubuntu-1210.html
Jarrod
Welcome to Ubuntu world. question you asked has a broader concept, i may require few answers from you :
  1. have you checked id your WIFI LED is glowing (or some other mechanism that lets you know that your WIFI is on).
  2. reply with what you see as a result of iwconfig on commandline.
Meanwhile you can try :
  • Disable the non supported driver.
  • Go to Synaptic and install b43-fwcutter and firmware-b43-installer.
Thanks.
PLUG IN ETHERNET CABLE
run these commands in terminal
sudo apt-get purge bcmwl-kernel-source broadcom-sta-common broadcom-sta-source
sudo apt-get update
sudo apt-get install b43-fwcutter firmware-b43-installer
THEN UNPLUG ETHERNET AND REBOOT
iainH
  • 808
  • 16
