after having installed ubuntu 13.04 i can not connect to the internet wirelessly or wired? can only connect to internet by using "try ubuntu" via ethernet cable, ive tried seeking help in so many different ways yet getting no positive outcome at all, will someone please explain why i can only connect with ethernet while i have the cd in the tray? ive also tried downloading b43 drivers to connect to the internet but apparently i dont have enough disk space, what is going on here?
i have the disk in the tray now at the screen where you can either try or install, if someone could give me a step by step from here it would probably cut out all this hassle of me not knowing whats going on
James
  • 19
Not sure if this helps, but I was digging around trying to find a place you could download the drivers and then install them but here's what I found
WifiDocs/Driver/bcm43xx
And
Package: bcmwl-kernel-source
Hope this helps.
There have been some issues with the network drives in ubuntu (and kubuntu). I've found that I have to use echo on | sudo tee /sys/class/net/eth0/device/power/control to get the cabled ethernet to come up.
If that works, you should then be able to download the drives you need for the wifi card.
Bug report is here ubuntu bug report
