I am using a Dell Inspiron e1505 laptop. I can connect with a wired connection but it doesn't pick up the wifi or I cant enable it at all. It's rather frustrating. Any help?
This is the actual steps to follow, some times wifi card may block.
Check if the wifi card is blocked (Terminal)
rfkill list wlan (for wifi)
OR
rfkill list all (for wifi and bluetooth)
UNBLOCK:
rfkill unblock wlan (for wifi)
OR
rfkill unblock all (for wifi and bluetooth)
Restart the network:
sudo service network-manager restart
I got the same problem to my laptop the above step does't work for me unfortunately this worked for me try this if the above does't work for you.
Actually I followed 2 step to enable wireless in my PC
Step 1 : Removed the bcmwl-kernel-source package
sudo apt-get remove bcmwl-kernel-source
Step 2 : Installed the firmware-b43-installer package.
sudo apt-get install firmware-b43-installer
And then rebooted my PC .
Finally got my work done. :)
Have you tried System Settings -> Additional Drivers?
Try that but, I've noticed an odd bug when installing Ubuntu in PC's Using Broadcom, before Install you must check if Wifi works normally, if is not that way you should check System Settings -> Additional Drivers and enable them before proceeding the Installation. If you not do this, when you try to install the additional drivers after ubuntu installation they are never detected properly.
- 339
Check Network Manager - does it have an Enable Wireless entry? If so, ensure that it's checked. If not, then the driver for your wireless device probably hasn't been loaded. Do lspci -k -vv | grep -A11 -i wlan (adjust the -A11 to ensure you see all the lines following wlan, e.g. -A12, -A25), and find out what your system knows about your wireless interface.
- 37,856
