-1
I just installed Wubi on a Dell Inspiron, and am trying to install the drivers for a Broadcom BCM4312 driver. I know this is a common question on the site, but I think I have tried every solution posed, and I still cannot get it to work. When I go into the jockey file, I get:
2013-08-24 17:10:10,049 DEBUG: BroadcomWLHandler enabled(): kmod disabled, bcm43xx: blacklisted, b43: blacklisted, b43legacy: blacklisted
I went into the blacklist.conf file and commented out
# blacklist bcm43xx
And I have restarted, even done a fresh install of Wubi. Nothing works. Any suggestions? Let me know know what further info I need to provide.
Based on request for further feedback, I ran this command:
lspci --n -d 1434:
And got the response:
0c:00.0 Network controller [0280]: Broadcom Corporation BCM4312 802.11b/g LP-PHY [14e4:4315] (rev 01)
For further information, I uninstalled wubi and installed Ubuntu 12.04 on a new partition of my hard drive (I thought that might help with the driver issues), but I'm having the same problem.
I am able to connect an ethernet cable to get internet directly onto the machine. And, when I had Wubi installed in a previous installation on the same machine, I was able to somehow get the wireless to work, so I'm pretty sure it can be done.
Unfortunately, this is a bug reported years ago https://bugs.launchpad.net/ubuntu/+source/bcmwl/+bug/511379
This is what you can try
Solution 1
sudo apt-get install --reinstall bcmwl-kernel-source
Reboot
Solution 2
Remove bcm-kernel-source, if present
sudo apt-get purge bcm-kernel-source
Make sure you got this installed (otherwise, install it)
sudo apt-get install firmware-b43-installer b43-fwcutter
Then, run
cat /etc/modprobe.d/* | egrep '8180|acx|at76|ath|b43|bcm|CX|eth|ipw|irmware|isl| lbtf|orinoco|ndiswrapper|NPE|p54|prism|rtl|rt2|rt3 |rt6|rt7|witch|wl'
If you see something like this
blacklist bcm43xx
Then
sudo gedit /etc/modprobe.d/blacklist.conf
If you don't have this anymore, then add the # again, to look like this
# blacklist bcm43xx
Reboot
Keep in mind that this is a unfixed bug, so neither of these solutions might work for you.
0R10N
  • 2,126
